Mirror extension problem.
Results 1 to 10 of 12
Like Tree2Likes
Thread: Mirror extension problem.
    Junior Member Badger's Avatar
    Feb 2014
    Sechelt, BC Canada
    26
    Have any others had this problem? I ordered a left and a right mirror extensions from Amazon.
    Right hand mirror on TDub has a left hand thread. Both extensions although marked left and right on the packaging come with a right hand bolt. I think I am going to have a tough time finding a left hand thread bolt. For the price of these things it is hardly worth sending one back.
    Any ideas?
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    You need a Yamaha mirror adapter.
    Yamaha Reverse Thread Mirror Adapter - TwistedThrottle.com
    Available from most motorcycle parts vendors.
    jb
    18,698
    I do not recall who the vendor was but I saw for sale on internet an adapter piece with both clockwise and couter-clockwise threads for just this problem. Maybe someone else with better memory or internet search skills can point you in right direction.
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    There are several vendors that sell adapters, I think that Pro Cycle sells them. Since mine was stripped I ended up drilling it out and installed a heli-coil insert with right hand threads.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    The manufacturer / seller should have sent you a LH threaded bolt for the right side.
    Check out Luckybike.com ( SKU # 122-100).
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by jbfla View Post
    jb
    I get an "Error 503" when I click on the link ?.
    Feb 2014
    Sechelt, BC Canada
    26
    The mirror extensions I bought came from luckbike. I bought a right and a left both have right hand threaded bolts.
    FL. GA, NC
    2,396
    Quote Originally Posted by frog13 View Post
    Sorry, Frog...it works from my iPad.
    Nevertheless, it is an example of the adapter from Twistedthrottle.com that is readily available from most parts vendors.
    jb
    Sep 2012
    Northwestern Oregon
    1,092
    Quote Originally Posted by Leben View Post
    Here is the adapter that ProCycle sells:
    Description:
    "This adaptor will give you more mirror choices. The TW200 requires a mirror with reverse threads on the right (throttle) side of the handlebars. This adaptor allows you to mount a mirror with standard 10mm threads on the right side of your handlebar. This opens up many options for your mirrors, choose any 10mm mirror for your T-Dub!"
    Jun 2011
    SW, Ohio
    2,518
    Hmmm ,maybe contact them and see if they will retify the issue......at their cost ?.
  1. Swingarm extension pieces.
    By Trikstr in forum Performance and Customization
    Last Post: 05-23-2014, 05:50 PM
  2. swing arm extension
    By TWGIRL in forum TW200 Classifieds
    Last Post: 04-16-2014, 08:17 PM
  3. petcock angle extension
    By danwray in forum Performance and Customization
    Last Post: 03-28-2014, 04:15 PM
  4. Pilot screw extension $30
    By gregor in forum TW200 Classifieds
    Last Post: 09-27-2013, 08:39 PM
  5. Possible swing arm extension
    By adam79 in forum Performance and Customization
    Last Post: 08-23-2010, 09:12 AM
