What size socket for the axel nut
Results 1 to 10 of 14
Like Tree3Likes
Thread: What size socket for the axel nut
    Member graxler's Avatar
    Mar 2014
    Northwest Indiana
    54
    I have 24 miles on mine and its finally time to tighten that chain up. That nuts a pretty good size so im guessing maybe a 1/2 inch socket. Figured I would ask before I take a trip to advance auto parts. Give your mom some flowers today! Or in my case a fifth of gentleman jack lol
    Mar 2011
    Gobles, michigan
    1,824
    19 mm.................. Lightly tap the snail adjustment cam one notch at a time....... It doesn't take much............Remember the dubs need some slack to run right.. Make sure you find the tight spot in the chain before adjusting. OMM.
    Mar 2014
    Northwest Indiana
    54
    what do you mean by the tight spot in the chain.
    Apr 2014
    Dryden NY
    6,338
    Quote Originally Posted by graxler View Post
    Roll the bike on a flat service and watch the chain. You will see that the chain is tighter along the bottom edge at some places and looser in others. You want to make sure you measure the chain at its tightest spot.
    Tom
    May 2013
    Groton, NY
    2,663
    The axle hex is 19mm and the nut is 22mm.
    goldenhtr likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Hailey, ID
    3,341
    If you want to take that nut off and put it back on more than once, you need a 22 mm socket or open end. You can hold the bolt with a crescent wrench, but using a 1/2 inch socket will only cause you grief. It needs 65 ft/lbs of torque.
    Get some Metric tools and a torque wrench!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Mar 2014
    Northwest Indiana
    54
    A torque wrench eh? sounds expensive. The tool bag that was given to me when I purchased the bike had 22mm wrench in there. Why didnt I check there first is a good question lol. even after a full mothers day meal I was unable to get the nut to loosen by standing on the wrench.
    Senior Member tcepilot's Avatar
    May 2013
    Dayton Ohio
    765
    Make sure you are not tightening it. Its not too difficult. Also make sure the other side isn't moving
    Sent from Android for Nook Tablet using Taptalk
    maddawgj likes this.
    -tcepilot Hidden Content
    --- Psalm 23 Verses 4-5 ----
    Even though I walk through the valley of the shadow of death, I fear no evil,
    for You are with me; Your rod and Your staff, they comfort me.
    You prepare a table before me in the presence of my enemies; You have anointed
    my head with oil; My cup overflows. (New American Standard Bible)
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    That's where a tool tube and longer wrenches help. I keep both long wrenches in the tube because it gives greater leverage and the 19mm is long enough to stop on pavement or a good rock so it won't move while I jump on the 22mm.
    Harbor Freight is your friend for cheap tools, torque wrenches are actually on sale right now.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Mar 2014
    Northwest Indiana
    54
    I pass a harbor freight on my way home from work actually I will have to go check it out. Thanks
  1. How to lubricate an old socket wrench
    By DanTW in forum Off-Topic
    Last Post: 06-11-2013, 02:28 PM
  2. WANTED 45 or 46 tooth rear socket
    By mkriley in forum TW200 Classifieds
    Last Post: 05-27-2013, 09:07 AM
  3. Stripped Mirror Socket
    By Avi Kwame in forum Technical Help
    Last Post: 02-25-2013, 05:37 AM
  4. Which way to take off back axel nut?
    By ceramite in forum Technical Help
    Last Post: 10-19-2011, 09:04 AM
  5. Is this a good deal for a socket set?
    By ceramite in forum General Discussion
    Last Post: 10-11-2011, 08:36 PM
2014 kx450 axel nut size
tw200 axel nut sizes
