Horn will not sound (but works on another bike)
Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By Dryden-Tdub
  • 2 Post By fasteer
  • 1 Post By rbm
Thread: Horn will not sound (but works on another bike)
    Junior Member LittleSpoon's Avatar
    May 2014
    Attica, Michigan
    6
    I'm new here and maybe not searching correctly (although I did find a lot results about "horns" in the Performance and Customization section).
    Love this site
    My 2005 TW 200 Horn is not working.
    However, the Horn itself works (put it on another bike and works just fine).
    Nothing happens when I push the button.
    The wiring looks ok (No obvious cracks or breaks).
    My BF used a test light and it seems to have a constant power. When I push the horn button it doesn't change or flash like on his bike.
    Took apart switch and connections look good.
    The lights and turn signals work just fine. Just when I push the horn button...nothing happens.
    Could it be the switch itself? Thinking of replacing the switch to see if that is it.
    Any suggestions? Something else to test?
    I currently don't ride many main roads. Mostly back roads. But you never know when you might need a horn.
    Thanks for your suggestions.
    Feb 2013
    Missoula, MT
    908
    "My BF used a test light and it seems to have a constant power" What? If it had constant power the horn would be making noise all the time. Wouldn't it? Where did you hook the test light?
    Your problem is either the switch or the wires. If the horn works on another bike, use your tester to see how the current flows on the good bike first, Then work on the broken one to make it act the same.
    May 2014
    Attica, Michigan
    6
    Thanks Fishguy.
    Good point and I forgot to mention that is what we thought about the horn making noise all the time too.
    He hooked it the same on his bike to compare and when the horn button is pushed it flashes the light on his. But on mine it doesn't flash...just stays on.
    Can just this Horn part of the Switch go bad?
    Apr 2014
    Dryden NY
    6,338
    Quote Originally Posted by LittleSpoon View Post
    Thanks Fishguy.
    Is your friend using a continuity test light? If he is that supplies its own power. He needs a multi-meter to check voltages at the ends of the wire that attach to the horn. You should see voltage when the horn button is pressed and none when it is not.
    Tom
    LittleSpoon likes this.
    May 2014
    Attica, Michigan
    6
    Thanks for the info & suggestion Tom.
    I will show him this and have him check it with a multi-meter. (He knows more than I do when it comes to this kind of stuff - as you can tell by my descriptions - lol).
    I appreciate the help.
    Member fasteer's Avatar
    Nov 2013
    Calgary
    90
    Possible that it's not getting ground.
    LittleSpoon and fishguy like this.
    87% of all statistics are made up right there on the spot.
    May 2014
    Attica, Michigan
    6
    Hi all,
    Sorry been a few days.
    Checked it with the Multi Meter and found that the Switch was good.
    Ended up being where the horn bracket mounts to frame. Good ground now and Beep Beep...Working!! YAY!
    Thanks all.
    Pegg
    2005 TW200
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Congrats!
  1. Carb substitution works great! Cheap, too.
    By cnc200 in forum Technical Help
    Last Post: 06-29-2019, 04:50 PM
  2. 450cc TW in the works!
    By rmcglad55 in forum General Discussion
    Last Post: 04-02-2014, 03:06 PM
  3. What hand protection works with stock bars?
    By Melbox57 in forum Performance and Customization
    Last Post: 03-01-2014, 08:38 AM
  4. TW from stock to my "Works" TW
    Last Post: 05-08-2013, 04:32 PM
  5. Magnet added to drain plug screen- really works!
    By Turwilliger in forum Technical Help
    Last Post: 11-30-2011, 03:20 PM
