Oil level
Results 1 to 8 of 8
Thread: Oil level
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    Oil level
    ???How do you check the oil level on a 1990 TW.I know where to add it but where to check it?
    Senior Member Dubzha's Avatar
    Aug 2013
    Twin Cities, Minnesota
    385
    There is a site glass on the right side of the crankcase. Hold the bike upright on level ground and look at it. Pretty simple.
    ~ Brian
    Life's too short to be in a hurry... Ride a T-Dub Hidden Content
    2013 TW200
    2004 VTX 1300
    Hidden Content The Spirit of the Lizrd Rolls Forever.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Sight glass on the right side. Make sure it's between the two lines.
    May 2014
    614
    Thanks.I don't know how I missed that.The oil is drained and I will finish up the oil change tomorrow.
    Member cbamarun's Avatar
    Aug 2011
    Atlanta,Ga
    91
    is there an o ring on the hex screw that you loosen to check the oil flow or just a metal washer?
    Senior Member indika666's Avatar
    Dec 2013
    Colombo, Sri Lanka
    109
    Quote Originally Posted by cbamarun View Post
    just a metal washer..! (click to enlarge)
    2006 TW200E (JDM) -> 100% stock, Shinko SR428 front, Bridgestone TW204 rear, 14/45 stock gearing
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    Warm the bike up for 6-7 minutes at idle
    Shut bike off and level the bike using some wood or phone books under the kick stand
    Just get it level. Wait 3 minutes then look at oil sight window and make sure the level is inbetween the 2 marks
    My 1989 tdub takes 1 quart and 1 half ounce after a filter and oil change
    Tip: I use a small magnetic level on top of the cross bar on bars to get it
    level
    Also never check the oil level when the bike is really hot! You will get a high inaccurate oil reading. Oil expands when hot
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    Aug 2011
    Atlanta,Ga
    91
    Thanks!
  1. Please help with oil level
    By Holdnon72 in forum Technical Help
    Last Post: 03-17-2014, 06:21 PM
  2. oil level help..
    By Alexander in forum Technical Help
    Last Post: 10-13-2013, 04:49 PM
  3. Jetting for Sea Level .... !!!!!
    By Alexander in forum Performance and Customization
    Last Post: 08-27-2013, 08:19 PM
  4. Oil level glass
    By osheen23 in forum General Discussion
    Last Post: 11-21-2012, 11:39 AM
  5. Fork oil level
    Last Post: 11-13-2012, 09:58 AM
checking oil 1992 tw 200 window
