87 tw 200 regulator / stator wiring question
Results 1 to 10 of 11
    Junior Member kens's Avatar
    May 2014
    4
    As I am new to the forum and sort of over whelmed by all the incredible info and sharing on this forum please bear with me in my first post as I bet this question has been asked before
    OK so I got a 87 tw200 in very nice shape on a trade for a pw50...good deal. The guy told me the TW died and had no spark so he gave up on it.
    I cleaned it up, changed oil, got it spinning nice with a booster battery pack, plug the cdi back in and hooked up my spark checker. No problem...it throw lighting bolts.
    Charged up the battery on a nice long slow charge and load tested it...looks good
    Fired it up today and it purrs threw the entire rpm range ( no load as it is in the shop half apart ) and checked the battery for charging.
    So it is not charging , just staying at nominal voltage and loosing slowly. So because I read all this weird stuff about the 87 model year my question is:
    does the 87 stator have 3 ac feed legs that feed into the regulator and is so what is a "good" AC output on this 87 tw200 ? Currently I have good Ac out on the white wire and nothing much on the other 2. is there something special with this stator that make sit different from other Yamaha bike/ quad motors?
    The 4 wire regulator.. can anyone give me some info on it and how it works on this bike
    So if I am asking questions that have been answered before please forgive me and send me a link.
    Thanks in advance and kudos on a great TW200 site !!
    Spokane, Washington
    17,283
    Will this help you Kens?
    1st John 1:9
    John 3:16
    John 3:17
    May 2014
    4
    wow, yes this help tremendously, thanks.
    So from what I see the white and yellow should have ac output then ?
    Spokane, Washington
    17,283
    Better to wait for another member to come along and answer that. I have the schematic but that doesn't mean I can read it... ha ha
    1st John 1:9
    John 3:16
    John 3:17
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by kens View Post
    Yes it is AC.
    May 2014
    4
    no prob but should be AC output on both yellow and white then.
    Currently I have at idle:
    white 13 vac
    yellow 6 vac
    on my Yamaha timberwolf quad this was way to low output and I had to replace the stator. Any input for a tw200 spec or member experiences with the 87 year ?
    Junior Member owensexport's Avatar
    Feb 2014
    Chatsworth, CA
    10
    I would think you should be measuring from the yellow to the white wire for AC.
    The rectifier in the regulator assy will convert that to DC that you would measure to ground
    from the red wire.
    If you dont get anywhere, I can check it on my 87 as soon as I get the forks back together.
    May 2014
    4
    Quote Originally Posted by owensexport View Post
    from the red wire.
    What does your 87 measure for ac output when measured between the yellow to white ? idle and 2000 rpm ?
    Junior Member Jhlebain's Avatar
    Aug 2014
    8
    What did you find out the problem is I have the same exact thing going on
    Junior Member BenvanZyl's Avatar
    Aug 2017
    Botswana, Africa
    Now I need the clever guys on this matter. The later TW's, like the one I am rebuilding, have 4 wires instead of two ...
    Instead of just the Yellow and White (as per the diagram) mine have One by Yellow and Three by White wires, all severed ....
    Now on the Supplementary (01 onward) manual they show the 4 wire setup, but with all severed, which white from the alternator goes to which white on the Regulator / Rectifier unit???
    Regards
    Ben
  1. LED Lighting-Voltage Regulator Question
    By Ice_Man in forum Technical Help
    Last Post: 10-22-2013, 10:28 AM
  2. Replies: 0
    Last Post: 09-02-2013, 06:32 PM
  3. regulator /rectifier question
    By Camelrider in forum Technical Help
    Last Post: 12-15-2012, 07:50 AM
  4. 87 Project and wiring question
    By Johnywad in forum Performance and Customization
    Last Post: 12-07-2011, 12:54 PM
  5. Wiring Question - Where does this wire go???.
    By Grant in forum Technical Help
    Last Post: 12-25-2010, 12:31 PM
1978 tw 200 cdi yellow wire
87 tw200 ricky stator
87 tw200 stator output
87 tw200 wiring
tw 200 electrical wiring diagram
tw 200 regulator
tw200 stator output
tw200 wiring diagram
yamaha timberwolf wiring diagram
yamaha tw regeulator wire code
yamaha tw200 rectifier wiring
