My First Fall
Results 1 to 6 of 6
Thread: My First Fall
    Junior Member LBtire84's Avatar
    Nov 2010
    4
    Today is the first day it has not rained in southern California in a week, so i decided to take my bike out. When I was slowing to make a turn my bike skidded. So i panic in fear of hitting the curb of other motorist. I slammed the brakes and turned, skidding and falling in the process. I damaged my taillight and engine makes a buzzing sound. Any ideas, advice, help on the problem.
    Desert, SoCal
    7,369
    Quote Originally Posted by LBtire View Post
    Unless you tweeked your engine side covers in the fall, it's very likely that you loosened something else up in the fall and it's resonating, rather than your motor. Check your subframe to see if it's tweeked and make sure your airbox, fender, skidplate, exhaust and plastic are firmly attached and aren't buzzing on the frame somewhere, etc. Press down on the tank and various parts while you're riding and see if you can isolate the noise.
    1993 TW200 in Meridian, Idaho
    1,533
    My fall resulted in busting pieces loose inside of what was a pretty rusty muffler. I wound up buying a good used OEM replacement muffler via Ebay and junked the old one.
    Nov 2010
    4
    Thanks guy but I'm not sure what it could be. The engine won't start at all, blinkers don't work, and my headlight is really low.
    Desert, SoCal
    7,369
    PM'd you. Check your mail.
    Where in Socal are you that it isn't raining? I'm building an ark up here.
    Did you dump it on the lift side and prang the case cover into the rotor?
  1. Let's see some fall color!
    By surly357 in forum Trails, Off-road, and Adventure Riding
    Last Post: 11-01-2018, 09:10 AM
  2. Arizona fall colors
    By xdac in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-12-2012, 10:02 AM
  3. secret spot fall colors
    By yamamont in forum Trails, Off-road, and Adventure Riding
    Last Post: 11-01-2011, 07:50 PM
  4. Beautiful ride, fall color and all
    By yamamont in forum Off-Topic
    Last Post: 10-30-2011, 07:02 PM
  5. Kolob Fall Colors Tour
    By B-dub in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-21-2011, 02:52 PM
