what is this? Clutch cover slotted plastic screw?
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By admiral
Thread: what is this? Clutch cover slotted plastic screw?
    Member george_c's Avatar
    Mar 2014
    36
    What is it? what does it do? The plastic head screw that is installed/removed with a huge flat head screw driver. The PO of my bike stripped out the screw driver slot, so I need a new one.
    Frosty Hollow
    13,052
    I think you mean the left side of the engine, which is the stator side.
    Clutch side of engine looks like this
    Stator side looks like this
    The plastic slotted screws are for: small top one = timing mark; larger center once = access to crankshaft so you can rotate the engine using a socket. Normally accessed when aligning timing marks to adjust valves.
    Hope this helps!
    Take care.
    Leisure Time Larry likes this.
    Mar 2014
    36
    admiral it is the stator side. it is the timing mark screw thanks.
  1. Replies: 4
    Last Post: 04-24-2014, 12:41 PM
  2. Side cover screw replacements
    Last Post: 12-01-2012, 09:35 AM
  3. Replies: 6
    Last Post: 09-11-2012, 05:17 PM
  4. Plastic right side cover needed
    By sbobroff in forum TW200 Classifieds
    Last Post: 08-17-2012, 12:25 AM
  5. Still looking for right side plastic cover - anyone?
    Last Post: 12-14-2011, 07:09 AM
