I've sprung a leak!
Results 1 to 10 of 17
Like Tree5Likes
Thread: I've sprung a leak!
    Senior Member tcepilot's Avatar
    May 2013
    Dayton Ohio
    765
    I've sprung a leak!
    Rode it for about an hour and immediately was leaking when I parked it.
    Any Ideas?
    -tcepilot Hidden Content
    --- Psalm 23 Verses 4-5 ----
    Even though I walk through the valley of the shadow of death, I fear no evil,
    for You are with me; Your rod and Your staff, they comfort me.
    You prepare a table before me in the presence of my enemies; You have anointed
    my head with oil; My cup overflows. (New American Standard Bible)
    May 2013
    Dayton Ohio
    765
    I didn't realize some were out of focus until I posted them. Oh well. The swingarm has oil just sitting there on top. The kick starter I think is just gunk from other stuff. It looks to be coming from the middle of the case. I really don't know. All of the fluids are darker in person.
    Senior Member Borneo's Avatar
    Feb 2014
    6,368
    Wipe it down and figure out where it's coming from tce.
    my blog Hidden Content
    Senior Member troll's Avatar
    Nov 2013
    frozen wasteland of the barren north, Yukon Territory, Canada
    1,202
    I'm with Borneo on this one, clean the engine up really good and then see where the oil shows up. after it is clean don't run it to long before checking for the leak. You will want to see before to much oil gets on things again.
    May 2013
    Dayton Ohio
    765
    That is what I was thinking of doing. A bit late tonight though. I just hope its not coming from the cylinder head. That would explain a drenched swingarm.
    Fred likes this.
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    567
    My best guess is shift shaft seal given the age. If it doesn't look to be the culprit then be prepared to go in for the countershaft seals on both sides of the sprocket. Pray it's not a crack.
    May 2013
    Dayton Ohio
    765
    Quote Originally Posted by TWrider View Post
    That area is pretty dry as of now. It looks to be coming from higher up. I will just have to clean it up and see. Part of the exhaust had oil splashed on it too. Close to the the gasket they meet at.
    Feb 2014
    6,368
    I'll bump you up tce. Get it cleaned off and find the leak. These guys here are good, but you need to provide them with precise information if you can. That makes everything go smoother.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,038
    I get a couple drips of oil after each ride on the garage floor. Went through all of the above possibilities and after wiping all the possible seams and gaskets totally dry and allowing it to sit over night I came out to find another drip but all seams were totally dry. My drips come off the very bottom rear of the chain seal guide. While tipped sideways on the stand the lowest point is the chain seal guide. All I can come up with is either lubrication oil from the chain or the grease in the swing arm causes a drip or two after getting warmed up from riding and it ends up on my garage floor. It is of no consequence at all and I gave up concerning myself with it once I realized that both of my TWs do it and both have just had new chains, new sprockets, new side cover gaskets, all three shaft seals and the 88 got a brand new chain seal guide.
    There is a bearing and seal in the side cover, think it is named the outer bearing and seal. The shaft lubricates that bearing through the hole in the center. Any oil left in the side cover outer bearing cavity will eventually seek a way out and the path is along the shaft and then down the front sprocket to the chain and then it finally drips on to the floor.
    Go for a ride and place a piece of cardboard right under the kick stand and between the chain guide.
    1987 Yamaha BW350 Big Wheel
    6,975
    Check the neutral light switch. Red arrows point to where it leaks.
  1. Oil Leak
    By ldw72120 in forum Technical Help
    Last Post: 02-25-2013, 08:49 PM
  2. oil leak from where
    By jerz006 in forum Technical Help
    Last Post: 07-07-2012, 06:00 PM
  3. Oil Leak
    By B-dub in forum Technical Help
    Last Post: 08-09-2011, 01:19 AM
  4. Oil Leak
    By Mike Mecredy in forum Technical Help
    Last Post: 07-19-2011, 06:15 PM
  5. Spring has sprung!
    By jontow in forum General Discussion
    Last Post: 04-04-2011, 08:27 PM
