1st Oil Change... 78miles.
Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By sp_cache
  • 1 Post By RockyTFS
Thread: 1st Oil Change... 78miles.
    Senior Member sp_cache's Avatar
    Apr 2014
    Fort Worth, Texas
    182
    On top of all the other chores I had going on today, I made some time to wash the bike and change the oil. Lots of metal on the filter, not surprised with a hard break-in. Looks like the filter is doing its job. I went ahead and put in new pleated filter I may clean old one for a spare. Also noticed a couple large shavings on the oil plug spring. I'm hoping to change it again in the next 75 or so miles. DSC02653.JPGDSC02657.JPG
    Dubzha likes this.
    '73 CT-90
    '14 TW200
    Cycleracks Rear rack, Jimbo shield, Gmax dual sport helmet
    6,975
    Quote Originally Posted by sp_cache View Post
    Just make sure the 4 holes are in the other end of the filter.
    Apr 2014
    Fort Worth, Texas
    182
    Yep its got 4 holes. Also bled the screw.
    littletommy likes this.
    '73 CT-90
    '14 TW200
    Senior Member fandango's Avatar
    Dec 2013
    long island
    309
    I changed my first at 250 miles. Had a little more then yours as far as metal shavings. Hard break in for mine and replaced with new pleated metal filter oem yamaha part.
    Senior Member Indiana's Avatar
    Oct 2013
    Indiana, 40 miles south of Indy
    470
    Should look like this:
    Hailey, ID
    3,340
    ......... Lots of metal on the filter, not surprised with a hard break-in. Looks like the filter is doing its job.
    Yup, that's completely normal at break-in. Next change at about 200 miles, then 600, then 1500 and after that go to about 1500 miles with a filter cleaning at 750 mile intervals until it stays clean. If you use it for longer trips you can go to 3,000, but for most of us 2,000 is about right, or every six months. (That's with full synthetic, more like 1,000 with dino.)
    I'm still using the original non-pleated filter at 7,500 miles, just because it's easier to see the metal. I have the pleated as a spare if the original collapses or tears.
    sp_cache likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Oil change
    By osheen23 in forum Technical Help
    Last Post: 04-24-2016, 10:23 AM
  2. Ever change the TW?
    By Woodi23 in forum General Discussion
    Last Post: 02-08-2013, 11:49 AM
  3. Cam change?
    By RingSteel in forum Technical Help
    Last Post: 01-22-2012, 08:19 PM
  4. How to Change your own oil
    By goldenhtr in forum Technical Help
    Last Post: 08-02-2010, 07:40 PM
  5. How to Change your own oil
    By goldenhtr in forum Technical Write-Ups
