Fork squeak?
Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By RockyTFS
  • 2 Post By scotti158
Thread: Fork squeak?
    Member btrnrsntfl's Avatar
    Central Missouri
    78
    Fork squeak?
    I noticed a sound coming from the front end of my wife's 2012 TW that sounds like a cross between something tapping the fairing and the scrub of rubber on steel that only happens when the fork is cycled pretty hard. I haven't found any loose parts or anything out of the ordinary with the front end and the sound seems to be coming from the fork seal area. The forks operate normally and the bike has only 250 miles on it, 112 when we picked it up so I doubt it is wear or anything similar. Anybody else ever experience this?
    Is it possible that sitting for two years dried out the fork seals?
    May 2013
    Groton, NY
    2,663
    TW's are known for a "clunk" in the forks when hitting bumps, this might be the sound your hearing.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Central Missouri
    78
    I have twin 2012's and this is the only one that does it out of the pair. Here is the sound:
    I pulled the boots and the seals look good. Should I not worry?
    ETA: The other one makes the noise too, just half as loud. On a not so related note, the bikes appear to be 37 bikes apart, if you discount the 9th "check" digit in the VIN. Small world...
    Hailey, ID
    3,340
    Yup, that's the infamous TW CLUNK! Many hours have been spent by many people trying to figure it out with little success. Don't worry, be happy!
    btrnrsntfl likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    May 2013
    Groton, NY
    2,663
    That noise is also known as a Bump Indicator, when you hear it, you've hit a bump. Standard equipment on most TWs.
    btrnrsntfl and tcepilot like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Central Missouri
    78
    Thanks! I guess this is the perils of having identical bikes, they are not so identical after all.
  1. rear shock squeak
    By fandango in forum Technical Help
    Last Post: 05-25-2014, 08:27 AM
  2. Front wheel squeak
    By chevyy1212 in forum Technical Help
    Last Post: 06-19-2013, 10:38 PM
  3. WTB 2001-newer front fork legs/lower fork legs/front wheel
    By jeadra in forum TW200 Classifieds
    Last Post: 05-06-2013, 01:04 PM
  4. rear shock squeak
    By sdim66 in forum Technical Help
    Last Post: 05-20-2012, 12:29 PM
  5. Engine Squeak
    By assquatch20 in forum Technical Help
    Last Post: 09-19-2011, 08:51 AM
klr 650 squeaks when i hit bumps
klr650 rear shock squeak
