2000 TW Clutch Won't Disengage
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By rbm
  • 1 Post By elime
Thread: 2000 TW Clutch Won't Disengage
    Junior Member padillamia's Avatar
    Feb 2014
    29
    So the other day I went riding with a buddy of mine. On the way home, the bike started slowing down and the rear tire locked up then the bike shut off. The clutch wouldn't disengage after that happened. The clutch cable is still connected and I can see the spring by the case is still there and it turns when I press the lever. I tried the rocking back and forth to free it up but no luck. Never taken a motorcycle clutch apart before so I haven't been able to check it out. Any ideas?
    Sent from my SGH-T989 using Tapatalk 2
    '00 TW200 680 Miles Hidden Content
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Do you have oil in there?
    1 Bad dog likes this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    And if there is oil in it is it the correct oil designed for motorcycles with wet clutches?
    1987 Yamaha BW350 Big Wheel
    6,975
    Was there a "screeching" sound from the engine?
    Did you change the oil filter about 25 miles ago?
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,241
    I don't know exactly how the oil system works on our TW's. If the clutch is supplied by the oil pump, this could happen because the plate and disc are disengaged with one set turning because the bike is in first gear and the other set is not because the engine is off. If the clutch is supplied by splash , oil type, or as Tony suggest, a wrong oil filter could come into play. It will be interesting to hear the true cause so it doesn't happen to anybody else.
    Joe
    Feb 2014
    29
    Nope no new oil filter. It may have been a bit low on oil though.
    6,975
    See if pointer still aligns with the embossed mark on the crankcase.
    If it does or is very close I think you are all right.
    If it doesn't I bet the locknut came loose and the internal clutch adjustment is now wrong.
    fishguy likes this.
  1. 2000+ members!!!!
    By Sly Fox in forum General Discussion
    Last Post: 09-07-2014, 09:30 AM
  2. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  3. Pre-2000 TW with DG exhaust need help
    By kennethshaw in forum Technical Help
    Last Post: 08-17-2012, 12:23 AM
  4. Clutch won't disengage
    By Guit4eva in forum Technical Help
    Last Post: 06-25-2012, 09:41 PM
  5. Clutch Wont Disengage
    By dbreinich in forum Technical Help
    Last Post: 03-27-2011, 07:50 AM
