Loose shifter and kicker.
Results 1 to 6 of 6
Like Tree7Likes
  • 1 Post By uncle tim
  • 5 Post By elime
  • 1 Post By frog13
Thread: Loose shifter and kicker.
    Senior Member tcepilot's Avatar
    May 2013
    Dayton Ohio
    765
    My shifter lever is a bit loose. It is tightened all the way. Is there anything that I can put over the threads to tighten it? Also having this issue on our 83' Xl600r shifter and kick starter. ( horrible rattling on the 600 )
    Sent from Android for Nook Tablet using Taptalk
    -tcepilot Hidden Content
    --- Psalm 23 Verses 4-5 ----
    Even though I walk through the valley of the shadow of death, I fear no evil,
    for You are with me; Your rod and Your staff, they comfort me.
    You prepare a table before me in the presence of my enemies; You have anointed
    my head with oil; My cup overflows. (New American Standard Bible)
    Member uncle tim's Avatar
    Mar 2014
    Lakota ND
    79
    Use bearing mount, I like the loctite or john deere stuff. It's supposed to be able to fill gaps up to .020. I've used it on my skidder and it does work quite well for tightening loose splines on shafts. Just make sure you degrease and clean the surfaces first and use a pick to clean any loose aluminum from the splines before you start.
    Fred likes this.
    6,975
    Take the shifter off the bike. Remove the bolt. Put shifter in a vice and squeeze just tight enough so the metal clamp parts makes contact. Use a hacksaw and cut down between the contact of the two pieces of metal. Reinstall on bike and it should now tighten up.
    May 2013
    Dayton Ohio
    765
    I'll give it a go
    Senior Member Dell's Avatar
    Aug 2012
    139
    I think you are describing an external loose kicker, but mine got sloppy inside, as in shaft play in and out. For this I added another spacer inside, which worked great. -Dell
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    More good past info.
    tcepilot likes this.
  1. Kicker and Pusher
    By Mongol Pete in forum General Discussion
    Last Post: 10-12-2013, 04:06 PM
  2. tappet nut came loose
    By greendub in forum Technical Help
    Last Post: 04-29-2013, 08:32 PM
  3. WTB: footpegs, rear pegs, brake lever and kicker - '92
    By wdaloz in forum TW200 Classifieds
    Last Post: 10-10-2012, 10:55 PM
  4. Loose Dogs
    By ericj in forum General Discussion
    Last Post: 06-15-2012, 06:26 PM
  5. Kicker
    By Larry in forum General Discussion
    Last Post: 08-01-2010, 09:16 AM
