Not another Newbie question
Results 1 to 4 of 4
    Member harleyjoe43's Avatar
    Nov 2010
    Ocala Nat'l Forest
    44
    From what I read on other blogs, late model TWs have double walled gas tanks. I discovered a small ding on my TW's gas tank so if indeed it has double walls, my idea about trying to get out the ding from the inside is a no-go. Does anyone here verify this. Thanks in advance, Joe
    '08 TW 200
    '00 HD XLH 883
    Senior Member sinophilia's Avatar
    Aug 2010
    Verona, Italy
    522
    Never heard of double walls...
    Well if you can touch the ding with your hand from inside the tank then definitely there's no double wall
    Red Max - 1996 TW200 - 14/45, 320mm toothed brake disc, X-Racing titanium exhaust, Ricochet skid plate, Mule hitch pins, large pegs, VeeRubber VRM274&275 tires
    Senior Member TK200's Avatar
    Oct 2010
    Streator Il.
    369
    You can try and fill it up with water then sticking it in the deep freezer for a few days. Cheap fix when it works.
    Desert, SoCal
    7,369
    No double walls. The smaller late model gas cap opening makes it a bit harder to reach in there to work out dings than the earlier models, but it can be done.
  1. Newbie Tech Question
    By ColoradoKate in forum Technical Help
    Last Post: 05-27-2013, 02:54 PM
  2. newbie
    By Paulp1 in forum General Discussion
    Last Post: 02-10-2012, 09:02 AM
  3. Replies: 6
    Last Post: 10-17-2011, 12:24 PM
  4. Newbie Question on Rack and Hard Case
    By wilco in forum General Discussion
    Last Post: 04-05-2011, 12:10 PM
  5. Oh no,not another newbie !!
    By harleyjoe43 in forum General Discussion
    Last Post: 11-13-2010, 08:19 AM
