Loose Back Sprocket
Results 1 to 10 of 17
Like Tree6Likes
Thread: Loose Back Sprocket
    Member Tyler's Avatar
    Oct 2012
    Manitoba
    69
    Loose Back Sprocket
    This past weekend right before I installed that kicker, I put a real HARD trail ride in. Very sandy trails, hills, whoops and an all around just aggressive ride on the TW. I was keeping up to a '83 XL 250 and a '04 DRZ 400. So when I was pulling the clutch basket off, with the " in gear, foot on brake" method, I noticed some movement in my back sprocket. I checked and all the bolts were loose! I assume it was from that hard ride but to be honest, I'm not sure how long they've been loose. They're tightened back up now.
    Thought I'd share, as it seems to be something worth checking from time to time.
    Mar 2011
    Gobles, michigan
    1,824
    If you bend the tabs on the nuts correctly it should keep it tight for a looooooooooooooooooooooooooong time?????????? OMM.
    Senior Member docjekyll2002's Avatar
    Aug 2013
    648
    I have a feeling that the next time i replace the rear sprocket, all the tabs will break. Should i buy some replacements on ebay or not bother?
    Spokane, Washington
    17,291
    Buy a replacement. You need that secondary safety.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,048
    The tabs are designed for two changes. Some of the bent tabs can be re used if they don't crack or brake on flattening them.
    A loose rear sprocket is your first indicator that you are not doing a pre ride safety check which is your first and very best defense against a catastrophic failure on the road. I have found many loose screws, nuts and bolts when doing my pre flight inspections and vibration is the cause.
    Fred likes this.
    1987 Yamaha BW350 Big Wheel
    Apr 2014
    Dryden NY
    6,338
    Care to expound on that Gary? Since I am new to this model it would be nice to know of any particular nuts and bolts that may be repeat offenders. Thank you in advance
    Tom
    Jun 2013
    Forestburgh, NY
    8,048
    Quote Originally Posted by Dryden-Tdub View Post
    Tom
    Sure Tom. The TW is a single cylinder engine that revs quite high and has an inherent vibration factor as any single will. I spend probably 5 minutes checking the bike before I ever start it up.
    Make sure the levers and controls on the handle bars are all tight and the pivot bolts in the levers have not lost the nuts on the under side. Check both the front and rear axle bolts and nuts and the cotter pins. Check the chain and master link for adjustment and lubrication. Check the chain guard and rear sprocket bolts for any loose or missing bolts. Check the foot pegs for loose bolts and also the shifter. The air box side cover has two exposed screws that like to rattle out. Check all lights and blinkers for proper function and look for leaks around the carb, engine and under the bike where it was parked, check the oil level and if you have a front disc check the fluid reservoir. Check tire pressure and inspect tires for nails or other problems such as a dented rim or a weather crack or bubble. Check to be sure the engine bolts are tight, many have found them backed out under the seat or loose on the front down tube.
    Before I leave my driveway I check the brakes.
    I rode a buddies TW when I first learned about them and when we pulled in to a Yamaha dealer I went to down shift only to find the shift lever was gone. Any of these things can cause a catastrophic failure at 50-60 MPH so it is always in your best interest to be on top of your game for your own safety. Throwing a chain while cruising at speed can be deadly and also very expensive. While on a trail ride we took a smoke brake and I noticed my buddies front axle had lost the nut and was backed out about an inch, another inch and his front wheel would have fallen off. He forgot to tighten the nut and install the cotter pin. The first rule in riding is to check your ride!
    Dryden-Tdub and dette like this.
    Apr 2014
    Dryden NY
    6,338
    It is this type of response that makes this forum special! Thank you. Incredibly thorough as well. I have been really good about checking the big things before every ride "chain, axles, sprocket, etc" I can honestly say that I would never have thought to check the pivot bolts or the shifter though. I am going to give everything a good going over after my bike returns from its mandatory service by Yamaha. I have read on this forum the engine mounts have a tendency to loosen? I know this bike can be buzzy since I have logged 750 miles in a bit over a month and that has just been farting around after work and on weekends. This thing is addictive! Thank you once again.
    Tom
    Oct 2012
    Manitoba
    69
    I'm definitely going to give my bike a thorough bolt tightening check this evening.
    I usually ride quite a bit of highway kilometers, around 100kph, to and from the trails. Like mentioned above, this bike vibrates alot at that speed. So much that the mirros are basically useless!
    Mel
    Mel is offline
    Senior Member Mel's Avatar
    Jan 2013
    San Luis Obispo, Calif.
    1,174
    I like to do most of the bike inspection after a ride, because I will have a feel for anything that might have changed or reminded me to inspect. If I wait for the next ride, I may forget about something that should have been inspected. I also feel after a ride is when you are most familiar with the bike. I also like to push the bike forward and backward in gear to check chain and drive train looseness.
    Mel
    GaryL likes this.
  1. Back up her backside! The back way! Now with GoPro time-lapse pics.
    By DonBenito in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-16-2013, 10:23 PM
  2. tappet nut came loose
    By greendub in forum Technical Help
    Last Post: 04-29-2013, 08:32 PM
  3. Loose chain all of a sudden?
    By nfpgasmask in forum General Discussion
    Last Post: 10-11-2012, 10:51 AM
  4. Loose Dogs
    By ericj in forum General Discussion
    Last Post: 06-15-2012, 06:26 PM
  5. Valves - tight or loose?
    By jimgoose in forum Technical Help
    Last Post: 08-31-2010, 10:53 PM
