Need Help instaling right side crankcase after gasket replacement
Results 1 to 10 of 13
Like Tree5Likes
Thread: Need Help instaling right side crankcase after gasket replacement
    Member BikeNerd21's Avatar
    Feb 2013
    Santa Cruz Mountains
    94
    Bleh....I've given up for the night.
    Decided after a long day of work I would zen out on replacing the leaky gasket on my right side.
    Well...like most things I do..
    Took off fine...Now can't seen to figure out how to put it back on...
    I am a newb to this kind of mechanics...but really enjoy learning from my mistakes.
    Anyway, the problem is I cant seem to get the kick-starter to line up right. I've been looking at the manual, but the pictures are such bad quality...I cant tell how its set up.
    Now I realize this may be hard to explain over an email...But if anyone knows of a good tutorial to help me figure out what I'm doing wrong...it would be much appreciated.
    Thanks guys!!!
    your fellow Tdubber
    96' Rainbow Worrier, 47t Moose Racing sprocket, Renthal ATV bars, 04' XT225 fuel tank, Bridgestone tw203, tw204, Rock Oil full synthetic
    "Love Life"
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,249
    Make some guide studs. To make guide studs, cut the head off of bots that are longer than you need. Put the guide studs in finger tight and then just slip the cover on as the studs will assure perfect alignment. Secure the cover with a couple of bolts and then remove the studs and put the rest of the bolts back in. Hope this helps. Good luck.
    littletommy likes this.
    Feb 2013
    94
    Quote Originally Posted by Joemama View Post
    Its not the actual case I'm having trouble with...its the kick starter gears the aren't seeming to line up correctly...
    It's engaging the gears, but not budging at all....
    "Love Life"
    Feb 2013
    94
    i have a video i can post to show you what I'm talking about...
    "Love Life"
    Feb 2013
    94
    Alright, how does it align in when it goes back in?
    starting from the closest to me: Kick axle. theres the spring, which connects to the spring stopper...the washers (which i didnt touch)..the gear (thats stationary) the idle gear??? then a wire looking thing with a lip which I dont know the name of.. then the ratchet wheel paw which is supposed to line up with the ratchet wheel stopper......
    Am i making any sense?
    "Love Life"
    Pleasanton, CA
    5,747
    First of all, make sure that your transmission is in neutral so that things will turn freely. Unless you disassembled the kickstarter shaft assembly, it should still be assembled in the proper order. The closed loop wire spring thing on the non-splined end of the assembly should slip into a slot of some kind in the crankcase. Unfortunately, my pictures do not clearly show this slot and I can't remember exactly what it looks like or where it is located. When this closed loop slides into the slot, the non-splined end of the shaft should slip into the hole in the crankcase and the kickstarter gear should line up with the idler gear which is partially covered by the outer clutch basket. The open loop wire spring on the splined end of the shaft should then be rotated clockwise and looped over the post which is located at approximately a 4-5 o'clock position relative to the kickstarter shaft. I would then slide the kickstarter lever onto the splined shaft and gently rotate it in the direction that you would kick it to make sure that gears engage properly. If everything looks good, remove the kickstarter lever and proceed with replacing your side cover and reassembling things back together.
    BikeNerd21 likes this.
    Feb 2013
    94
    Thank you so much for the details! I will attempt again this evening.
    "Love Life"
  1. OEM fuel tank cap gasket replacement options
    By dreynolds in forum Technical Help
    Last Post: 05-31-2013, 06:40 PM
  2. Side mirror replacement
    By drs6222 in forum Technical Help
    Last Post: 09-21-2012, 08:56 AM
  3. Beginners Guide to Base Gasket Replacement
    By B-dub in forum Technical Help
    Last Post: 08-17-2011, 10:01 PM
  4. Beginners Guide to Base Gasket Replacement
    By B-dub in forum Technical Write-Ups
  5. Anybody need a left side cover engine gasket?
    Last Post: 09-18-2010, 08:08 PM
