1990 TW carb help.
Results 1 to 4 of 4
    Junior Member 90TW's Avatar
    May 2014
    6
    1990 TW carb help.
    So there's this hole in the left side of my carb, and, for the life of me I can't find out where or what connects to it. Need help Please! Thanks all.left.png
    May 2014
    6
    Also there is another drain type spout coming out of the bottom of the bell next to the drain spout what do I do with this hole aswell?
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    567
    The bottom drain is your overflow in case your float sticks... If that thing has been sitting with fuel in it, you're going to have to go in and clean that carb. My 87 has that hole plugged, maybe it just needs a vacuum cap. you're going to have to pull that carb anyways, because you going to need to check that the intake manifold hasn't become delaminated. I can tell that is the original because the rubber is all peeling away, definitely needs checking for air leaks. You may want to replace it for cheap insurance.
    I bet that carb need soaking in carb dip and all the passages need to be checked.
    Is that a teal beauty? How about a pic of the whole bike? Does it have the original seat and plastics?
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    Both of those holes are just blind holes in the body and neither are used. Could be for other applications if this carb was used on other bikes. The carbs on older XT 350 are the same as ours but have an additional linkage on the right side to connect it to another and completely different carb.
    1987 Yamaha BW350 Big Wheel
  1. 1990 TW Fix Up
    By RTG in forum General Discussion
    Last Post: 01-26-2013, 08:44 AM
  2. 1990 tw gas tank
    By zj_hummel in forum TW200 Classifieds
    Last Post: 11-04-2012, 03:04 PM
  3. 1990 carb Question
    By Gene-st1300 in forum Technical Help
    Last Post: 06-14-2012, 12:44 PM
  4. PA 1990 TW
    By collinbrackin in forum TW200 Classifieds
    Last Post: 09-26-2011, 04:29 PM
  5. 1990 TW 200 Carb Vent lines?
    By sasnydley in forum Technical Help
    Last Post: 03-15-2011, 07:00 AM
how to connect the lines to a tw carberator
tw200 forum 1990 carb
