Where can I buy Mikuni carb for 89 TDub?
Results 1 to 10 of 20
Like Tree3Likes
Thread: Where can I buy Mikuni carb for 89 TDub?
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    Anybody know where I can buy a Mikuni carb for my 89 tdub?
    Thanks for any links you may know of
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    Why Mikuni?
    1987 Yamaha BW350 Big Wheel
    Jan 2014
    New Jersey
    592
    I need a new carb for the old 89, so figured I could upgrade. Ive heard so many problems with the tk carbs
    The yamaha tech down the rd. Said Get a mikuni if I can find one
    I did just find a Pretty good deal on a oem tk for $260.00 new.
    Also when I buy a new carb...will it come with new drain hoses?
    Would you know what size drain hoses I would need to purchase if I bought the oem tk carb
    Mine are all brittle
    Thanks
    Jun 2013
    Forestburgh, NY
    8,047
    Quote Originally Posted by Holdnon72 View Post
    Thanks
    New TKs come with all the hoses you will need and some here have found them a bit cheaper, $240 + S&H I think someone posted. I bought 2 of them for my bikes at the $260 and it was the best money I spent so far. Drops right in and runs fine but remove the plug over the pilot adjustment before you install it and set the screw at 2 full turns out. Go from there once the bike is warmed up for fine tuning.
    Going to a different carb sounds good but can get expensive real fast and you will still have the same problems. It is the BS E-10 fuel we are forced to use causing 90% of our carb and tank problems. Pure gas, Burn it if you can get it.
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    229
    where is that $26 carb on Ebay ?
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
    Pleasanton, CA
    5,720
    Quote Originally Posted by greenbomb View Post
    Carburetor Yamaha BW 200 BW200 Big Wheel Bike 1985 1988 Carb NNN No | eBay
    Apr 2014
    229
    very fast of you TW Brian or is it Brain?
    Norm in Arkansas
    Pleasanton, CA
    5,720
    I just searched ebay for BW200 Carb.
    Jan 2014
    New Jersey
    592
    Gary if I get the oem carb, is it also a TK?
    Also what does 2 full turns out do? So you mean put that screw at 2 full turns out before putting carb on bike?
    Thanks
    Jun 2013
    Forestburgh, NY
    8,047
    Thanks
    Yes, you get the exact same carb as you have now, old style TK. When the carb arrives you remove the brass plug on the bottom that is covering the pilot screw. Then you turn the pilot screw all the way in until it bottoms out.no need to be tight, just till it hits bottom. Then you turn it back out two full revolutions or four half turns going by the position of the slot. It is much easier to do with the carb in your hands and this gives you a good starting point once you mount the carb.
    You can buy the $26 BW200 carb on eBay and others claim they work but are you mechanically proficient enough to overcome the modifications necessary? I am also sure there are other carbs out there that can be made to work but again, these are not for the novice who just wants to get his bike running. Unless you are very competent around tools and technical skills I highly recommend you just buy a new OEM stock Carb. You might also check the boot from the carb to the air box. These are known to get very hard and shrink making it very difficult to get a solid seal around the carb throat.
  1. need some pictures 2005 TDub carb
    By Jerry Lee in forum Technical Help
    Last Post: 08-07-2013, 07:45 AM
  2. Searching for a Mikuni TM28-1 pumper carb overseas
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 06-24-2013, 03:19 PM
  3. Mikuni TM28 Carb kit & Oem tk *SOLD*
    By PalmStateCrawler in forum TW200 Classifieds
    Last Post: 04-25-2013, 09:49 PM
  4. Is the OEM carb a Mikuni carb?
    By macbig2k1 in forum Technical Help
    Last Post: 01-29-2013, 05:50 PM
  5. Mikuni 30 MM ebay carb
    By Stromper in forum Performance and Customization
    Last Post: 11-08-2011, 01:16 PM
2jy 03 2k21 tk carbuerater
2jy-14301-00-00
mikuni carb for honda xr600
truckster cushman can i use a mikuni 22 mm carburator
