Shifter Question
Results 1 to 4 of 4
    Junior Member 2000TWThumper's Avatar
    Jun 2013
    7
    Shifter Question
    2000 TW does anyone know of any other shifters that would work on these bikes? Would like something a little longer and maybe a little more stronger/more substantial. Also, can anyone suggest the best set of sprockets, o-ring chain you've found? The stock chain is pitiful and I need to replace soon.
    Thanks.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    The stock Yamaha sprockets are good quality as are the ones I got after market from JT. The stock chain is cheap junk. I just put DID X ring chains on both TWs and I think these will be the last chains I ever have to buy. Others have found much cheaper O ring chains and seem to be happy with them to. I would not even bother replacing a standard roller chain with another roller chain.
    My stock shift lever was ok until I changed to wider foot pegs that I love. I also tried a nice pair of MX boots and could not even shift with them on. When I do change the shifter I will stick with steel just so I can bend it back if it gets bent.
    1987 Yamaha BW350 Big Wheel
    Senior Member Dell's Avatar
    Aug 2012
    139
    I've given some thought to a double action pedal-- a rocker type-- because it would be more precise with the ability to back-check. But it is all 'grown shut' behind the shaft. Has anyone else stewed over this? Dell
  1. Worn Out Shifter #'s
    By bluefox in forum General Discussion
    Last Post: 04-23-2014, 07:59 AM
  2. MSR longer shifter
    By GapRunr in forum TW200 Classifieds
    Last Post: 03-27-2014, 08:57 PM
  3. Folding Shifter
    By williamemack in forum General Discussion
    Last Post: 01-18-2014, 01:04 PM
  4. Shifter Seal Help
    By FishByte in forum Technical Help
    Last Post: 09-22-2013, 03:49 PM
  5. IMS Shifter Lever
    By nickpfrank in forum Performance and Customization
    Last Post: 04-05-2013, 09:29 PM
