mph needle indicator shakes
Results 1 to 9 of 9
    Senior Member fandango's Avatar
    Dec 2013
    long island
    309
    Question mph needle indicator shakes
    Hey anyone have this issue where the mph needle shakes a bit getting up to speed?
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Yeah, the cable probably needs to be lubricated. Look here for info about how to do it.
    Dec 2013
    long island
    309
    Thanks maybe I'll wd40 it. The bike is a 2014 though would it really need lube so early?
    May 2013
    Groton, NY
    2,663
    If the end of the cable gets bent a little where it goes into the speedo or at the engine, it will make the needle wobble a little.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Dec 2013
    long island
    309
    Should I bring it back to the dealership since it's under warranty? Or try to fix or just deal with it? It's not horrible but noticeable at times. .
    May 2013
    Groton, NY
    2,663
    Quote Originally Posted by fandango View Post
    I'd try the dealer first.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Dec 2013
    long island
    309
    True but then I have to leave there for a few days..
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by Croatoan View Post
    Just pick up some dry slide and spend an afternoon learning how to lube all your cables. If that doesn't cure it then it may be a warranty issue and you need to take it in to the dealer. Don't use wd40.
    +1! NO WD-40! Use proper cable lube or silicone...
    Dec 2013
    long island
    309
    Quote Originally Posted by scotti158 View Post
    I do see it looks like there is a kink in the cable. Is it fixable with lube?
  1. TrailTech Dashboard Indicator Wiring
    By Ice_Man in forum Performance and Customization
    Last Post: 05-15-2019, 09:48 AM
  2. Neutral Indicator Not Lighting
    By Timbo in forum Technical Help
    Last Post: 01-16-2017, 03:06 PM
  3. Speedometer and indicator lights
    By Kcfranqui in forum TW200 Classifieds
    Last Post: 11-28-2013, 02:47 PM
  4. WTB indicator lights housing/bezel
    By txarsoncop in forum TW200 Classifieds
    Last Post: 10-29-2013, 08:10 AM
  5. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
