Reassembling Carb for 2010 TW- ref plug ( item 21 )- is it a press fit??
Results 1 to 4 of 4
    Junior Member biker44's Avatar
    Apr 2014
    24
    I need assistance to determine if the small black plug, which shows up on the official Yamaha TW200 schematic as item 21. It is in the port next to the Pilot jet and Main jet. When I was cleaning the main carb body in my ultrasonic cleaner I noticed a small black plug in the bottom of the cleaner. Not sure what the function of the plug is. I think it goes as I described above, but it is not a tight fit. Do I need to bond the plug in place and if so what adhesive should be used? There is a post in the lower float body that seems to be just above the plug cavity, so I am not sure it that is what is supposed to hold the small plug in place. Or should I just order a new plug and wait another 7 days to put it back together ?
    I am going to install a #130 main jet and a #34 pilot jet and turn the pilot air jet out about 2 turns for a first shot.
    Thanks for your help,
    Frank
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    You do need that little plug in place, without it your choke wont work at all. On one of my TW's the prior owner had removed and discarded that plug and the result was a non working choke.. I made a new one by trimming down a peice of a rubber stopper and so far its worked prefect. I found a small plug at the hardware store, jammed it in the hole and trimmed it flush.
    Either way if yours is falling out i would replace it or make a new one. i supose you could try a fuel proof glue like this one Seal-All Adhesive Product Information although i would be hesitant about putting glue in my carb....
    Apr 2014
    24
    JB, thanks for the clarification- going to the local Yamaha dealer in the morning to see if they have the plug in stock. Got one more question for you- the small brass tube in the float bowl that is about 1 1/2 inch high--- does it act as some type of vent or drain? I don't think mine is clear. Do I have to push some type of wire down it to clear??
    thanks,
    Frank
    Senior Member gamorg02's Avatar
    May 2014
    Central NY
    174
    Quote Originally Posted by biker44 View Post
    thanks,
    Frank
    usually thats the overflow tube on carbs, I haven't gotten into my TW carbs yet so I can't be sure.
  1. What carb is stock on 2010 TW?
    By biker44 in forum Technical Help
    Last Post: 05-21-2014, 12:37 PM
  2. 1987 carb air fuel screw plug
    By Lido in forum Technical Help
    Last Post: 09-08-2011, 03:32 AM
  3. 2010 Carb question
    By RockyTFS in forum Technical Help
    Last Post: 03-26-2011, 11:31 AM
  4. Carb drain plug alternatives
    By kennethshaw in forum Technical Help
    Last Post: 03-17-2011, 01:33 PM
  5. Rubber Plug inside Carb Help Please! QWERTY??
    By Quicksand in forum Technical Help
    Last Post: 03-06-2011, 09:40 AM
