Please help with fuel pet-cock install
Results 1 to 10 of 13
Like Tree2Likes
Thread: Please help with fuel pet-cock install
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    Bought an oem Yamaha fuel petcock on ebay.
    Took it out of box and noticed it has a clear piece of rubber tubing over the longer strainer. Is this just there for packaging so strainer doesn't get damaged? The short strainer doesn't have it over it.
    Also I noticed some other aftermarket strainers on eBay come with to tiny o rings and 2 red washers. Do I need to purchase them as well? My oem came with rubber gasket but not the little o rings and washers. Thanks for any info
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    Senior Member Dubzha's Avatar
    Aug 2013
    Twin Cities, Minnesota
    385
    A) if that tube isn't gas resistant, it will be flotsam [ or is it jetsom] in the tank. Take it off before install.
    2) That tube [my opinion] is for shipping protection. Prolly on the longer one since it will likely rub the package more than the short one.
    I think all you need is the rubber gasket. They ship with what they [most commonly] need, or if none is in the box/package, you have to order it. Sounds like you have what you need.
    ~ Brian
    Life's too short to be in a hurry... Ride a T-Dub Hidden Content
    2013 TW200
    2004 VTX 1300
    Hidden Content The Spirit of the Lizrd Rolls Forever.
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    That is packing to protect the fine filter if it does not have a built in O-rings on the petcock and you are putting on stock metal tank you will need the o-rings.
    Jan 2014
    New Jersey
    592
    The oem pet cock that arrived has the shaped gasket attached to it. But I stumbled over an aftermarket tdub pet cock that has 2 mini o rings and also some rubber washers? Here is a pic of the after aftermarket one that comes with 2 mini o rings and 2 red washers.
    Do I need to purchase them separate? Thanks
    Member manotickmike's Avatar
    Apr 2013
    Ontario, Canada
    93
    Toss the tube. It's packing material, for protection.
    You don't need O rings. Your original screws will have washers on them, between the screw head and the petcock. The new gasket seals everything up.
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    Yeah what Mike said.I just replaced mine too.
    Jan 2014
    New Jersey
    592
    Thanks so much!
    Does the tank have to be removed or just pump out the gas?
    Senior Member Indiana's Avatar
    Oct 2013
    Indiana, 40 miles south of Indy
    470
    It would be a lot easier to just remove the tank. It's only one bolt (after the seat is off )
    Feb 2014
    Arizona
    4,030
    I drained the gas out of the tank on the bike with the petcock and fuel hose into a empty gas can. then removed the tank.
    Quote Originally Posted by Holdnon72 View Post
    Thanks so much!
    Well, if you drained the tank, you don't have to remove it, but I've never replaced or rebuilt a petcock on a tank that didn't at least need a good rinse with clean gas to dump dirt out the bottom.
    Normally I keep the crud out of the bottom of my tanks by using a small diameter fuel line hose clamped to the end of a long screwdriver or wooden dowel. Start the siphon and gently chase the gunk around until it goes up the hose. Just a part of my regular maintenance that prevents petcock, filter, and carb problems.
  1. TCI Skidplate install
    By lizrdbrth in forum Performance and Customization
    Last Post: 08-01-2017, 01:46 PM
  2. Jimbo Install
    By lyfestyl in forum General Discussion
    Last Post: 08-04-2012, 01:30 PM
  3. cyclerack install
    By howardgene63 in forum Performance and Customization
    Last Post: 04-09-2012, 08:28 PM
  4. Saddle Bag install
    By demarko69 in forum Performance and Customization
    Last Post: 07-22-2011, 10:57 AM
  5. Rotopax install
    By triple3jrb in forum Performance and Customization
    Last Post: 02-24-2011, 11:01 AM
yamaha fuel cock install
