Muffler Rattle Fix?
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By small's
  • 1 Post By elime
Thread: Muffler Rattle Fix?
    Senior Member RainWillFall's Avatar
    Jan 2013
    Niagara ON.CA
    127
    Muffler Rattle Fix?
    The Spark Arrestor / Muffler Cap has become loose and rattles around idle. I've removed it a few time tightened it up with lock tight but it still rattles.
    Has anyone experienced this and have suggestions for a fix?
    Cheers!
    Ryan
    '09 TW200 - Black Jimbo Shield - Custom Oversize Foot Pegs - Tusk T-10 ATV Sport Bend Bars - Hammer Black Cycle Rack - Tool Tube (Muffler Style Mount) - 15/50 Sprocket - HID Headlight - Custom Mount Ducati Monster LED Tail Light - LED Turn Signals - Eagle Eye Running Lights - OURY Road Grips - Shinko 700 Trailmaster Front Tire.
    Apr 2011
    Martinsville Indiana
    2,089
    My buddies 05 has done it a few times. You could just Tack weld it in a spot or two.
    RainWillFall likes this.
    Frosty Hollow
    13,042
    I can't even get mine off. Drilled out the old screw and everything. No budge. Don't feel like anything is wrong, but just wanted to check it cause they say you should!
    I like smalls idea for your issue.
    6,975
    There are some propeller looking fins that fit deep in the muffler on the piece you can remove. Bend them apart a little bit so they fit tightly and your problems will be solved for a little while. They will probably loosen up with time and use.
    Admiral -- I couldn't get mine out either but was bound and determined to do so and I ended up wrecking it, the part one removes to inspect. As it turned out everything was OK and I wrecked for nothing. Tony
    Fred likes this.
  1. End cap for my muffler
    By MCC1776 in forum Technical Help
    Last Post: 04-17-2014, 06:48 AM
  2. Rattle questions
    By oldmercman in forum Technical Help
    Last Post: 07-29-2013, 06:28 PM
  3. WTB Muffler
    By Gokeeper in forum TW200 Classifieds
    Last Post: 01-05-2012, 09:46 AM
  4. gas cap rattle
    By Sozzy1269 in forum Technical Help
    Last Post: 08-12-2011, 09:26 AM
  5. Do I need a new muffler?
    By thal13 in forum Technical Help
    Last Post: 05-31-2011, 12:22 PM
how to fix rattle in the ca muffler
