New battery dead
Results 1 to 8 of 8
Like Tree4Likes
  • 1 Post By Bruce's
  • 1 Post By goldenhtr
  • 2 Post By Schmitty
Thread: New battery dead
    Senior Member Schmitty's Avatar
    Dec 2013
    phila, pa
    206
    New battery dead
    Brand new battery with a full charge and after a 30 min ride its dead. It will start when I kick it but just clicking when I hit button. Do they have alternators?
    Sent from my SPH-L710 using Tapatalk
    Senior Member Bruce's's Avatar
    May 2014
    258
    They have something called a stator ,check your connections before doing anything else ,check your charging voltages before and after the regulator -rectifier .Procedures should be in the repair manual .
    671tdub likes this.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    What year TW and make of new battery ( new batteries can fail ). If you have another bike with a similiar battery, stick it in the TW for comparison.....troubling shooting .
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    The older tw's had a minimal charging system along with a 35 watt headlight. The later ones had a better charging system with a 55 watt headlight. many ov the older headlights get a 55 watt H4 bulb installed and that extra 2 amps will overload the charging system unless you are going freeway speeds and have it revved up. I installed a HID bulb in mine that uses 35 watts but only had a single beam. When riding trails I could switch off the low beam and turn the light off. I also installed LED bulbs in front turn signals and instrument cluster saving a little more power.
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
    Dec 2013
    phila, pa
    206
    It's a 98 and I bought one of the cheap ebay ones that I saw guys say worked ok
    Stanwood,Wa
    1,880
    Quote Originally Posted by Schmitty View Post
    Yep this can happen. Just e mail them and let them know. They should send you a new one if they don't want any negative reviews.
    Just tell them you are contacting them about your battery being dead on arrival and would like a replacement before you give any reviews.
    littletommy likes this.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    229
    Lifes too short for a cheap battery
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
    Dec 2013
    phila, pa
    206
    I have too many hobbies to buy top quality stuff. The wife will notice those purchases and expect to spend equal about on useless clothes
    rurlndum and goldenhtr like this.
  1. Dead battery question:
    By drake523 in forum Technical Help
    Last Post: 09-20-2013, 06:59 AM
  2. Troubleshooting a dead battery
    By atleastbehandy in forum Technical Help
    Last Post: 09-19-2012, 06:36 PM
  3. Battery discharge = dead tachometer
    Last Post: 06-11-2012, 06:43 AM
  4. Back from the dead
    By fishhuntr1 in forum General Discussion
    Last Post: 02-23-2011, 11:10 AM
  5. Good battery/fuse, dead bike?
    By Totally Wild in forum Technical Help
    Last Post: 09-28-2010, 01:55 PM
tw-200 battery discharging
