Is it necessary to replace plastic sleeve around carb joint?
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By scotti158
Thread: Is it necessary to replace plastic sleeve around carb joint?
    Senior Member docjekyll2002's Avatar
    Aug 2013
    648
    I peeled back a little of my cracked sleeve and looks like there's still a metal joint behind it intact.
    May 2013
    Groton, NY
    2,663
    With engine running, squirt a little WD-40, carb cleaner etc. at the boot. If engine rpm changes, it's leaking. If not, you're OK, for now.
    Fred likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Frosty Hollow
    13,052
    What scotti says. Mine is cracked and missing most if not all that black plastic and I'm not having any issue. But just to be safe ^^^^
  1. How easy is it to replace cam. Chain
    By Monztur in forum Technical Help
    Last Post: 09-23-2016, 12:47 AM
  2. I'd like to replace the coil.....
    By Landser in forum Performance and Customization
    Last Post: 02-27-2014, 06:51 AM
  3. Upcoming: Replace the Flag Ride
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 07-14-2013, 07:58 AM
  4. Replace Valve
    By fredzaha in forum Technical Help
    Last Post: 06-16-2013, 05:32 PM
  5. Should I replace the base gasket--2006
    By dganey in forum Technical Help
    Last Post: 05-05-2011, 08:20 PM
Tags for this Thread
