TW Kick start
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Like Tree11Likes
Thread: TW Kick start
    Senior Member cccan's Avatar
    Sep 2013
    Edmonton, Alberta
    193
    TW Kick start
    so I think I will take the plunge, I am going to install a kick start on my 2014.....the only parts I need are the kit 3RW-W0795-00-00 and the crank boss 54G-15621-00-00 ...is that correct?.....is it that difficult to install? or can a back yard hack stumble his way through?
    Pleasanton, CA
    5,720
    I didn't check to see if those numbers are correct, but if you mean the XT/TTR225 kickstarter kit and the TW200 crank boss, then yes that is what you need.
    It is not difficult to install. Hardest part will likely be removing the old gasket from the side cover. You also have be careful removing the inner clutch basket. There are several ways to do this (but using a screwdriver to hold the basket in place isn't one of them!).
    Here is a good tutorial that WhereTheHellIsJames? prepared (except that it is not necessary to remove your starter).
    Expedition Bike? Not really, it's just WTHIJ's TW200. - Page 2 - Expedition Portal
    If you get stuck or have a question, just ask.
    Brian
    Dryden-Tdub likes this.
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    Great idea to do this right away - you should have no trouble at all removing gasket andmay be able to reuse it. It's a super simple mod and an enjoyable one too. You'll love it.
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    229
    Get a set of heavy clutch springs while your at it . beats taking it apart later . $10 bucks on ebay or elsewhere and be there in two days . And it will be slipping sooner or later , or might not if you get the springs . I am not hot on shimming but others have done it.
    Under technical help look for the installing kickstarter and clutch stuff . the clutch spring issue will come up in one or the other As a matter of fact some are at the bottom of the page .
    Don't forget the grove at the bottom of the main case for the gear spring and the recess in the idler gear to the inside and might double check the seal install . Has fooled more than one.
    You can see the grove in the case below the kick shaft bearing ( where the shaft goes on the inside} and as you install the shaft you can see the spring going into the grove as you slide the shaft into the crankcase .. Put the idler gear on after the kickshaft is in place.. Remember the seal installs on the outside of the outer case
    Quote Originally Posted by cccan View Post
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Call Bay Area Yamaha ( 1-888-660-7766 ,their in Washington state if I remember correctly )....about $ 200.00 shipped , they will have the actual kit from Japan that will fit exactly...no messing around "finding " parts !.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by frog13 View Post
    This!
    Senior Member sp_cache's Avatar
    Apr 2014
    Fort Worth, Texas
    182
    Does Bay Area yamaha still carries this kit? I noticed some posts from 2011. Will the same kit fit the 2002 bike as well as 2014? I want to do this mod before I get back in the boonies loaded with gear. The kickstarter is cheap insurance in my opinion.
    Are clutch springs? I'm not against changing them while we have bikes apart, just would like to get some other opinions. Any advice is welcome.
    '73 CT-90
    '14 TW200
    Cycleracks Rear rack, Jimbo shield, Gmax dual sport helmet
    Member c.salt's Avatar
    Jun 2014
    39
    Mail man just dropped my kickstart kit at the door from Bay area yamaha
    May 2013
    Groton, NY
    2,663
    This is where I got mine. Came with directions, pictures, and service manual on cd.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Apr 2014
    Fort Worth, Texas
    182
    Good deal. I will call them next week. Thanks for info.
    '73 CT-90
    '14 TW200
  1. Kick & Electric Start ?
    By agent178 in forum General Discussion
    Last Post: 06-03-2013, 07:26 PM
  2. Kick Start Lever
    By xjnewfie in forum General Discussion
    Last Post: 04-16-2013, 06:39 PM
  3. Kick Start
    By island in forum Technical Help
    Last Post: 10-28-2011, 06:19 PM
  4. Clutch and Kick start
    By Henrici in forum Technical Help
    Last Post: 01-31-2011, 03:14 AM
  5. tw200 kick start
    Last Post: 01-20-2011, 08:42 AM
diagram kick start yamaha tw 200
tw200 expedition portal
yamaha tw200 kick start
yamaha tw200 kick starter kit
yamaha tw200 kickstart
