tubeless tire and headlight switch help
Results 1 to 4 of 4
    Junior Member pumpgear's Avatar
    South Florida
    14
    Hello,
    I'm a new rider and owner of a 2001 TW200 and had a couple questions I hope someone can answer. First of all I should tell you I have very little motorcycle knowledge but hope to learn more by spending more time on your site. The type of riding will be strictly off road with lots of water and mud.
    1. I'm worried about getting a flat way off road and was wondering if there were tubeless tire or other tire options available?
    2. I unplugged one of two wires that went to the headlight which gave me the ability to turn off the headlight with the main headlight switch. Does anyone know if this can cause any unwanted electrical problems?
    Senior Member rm_hm's Avatar
    1,619
    The only tubeless setup on the back tire I have seen is here.
    Our tires are too big for the common tubeless kits. For some $$$ you could try and find custom rims without spokes somewhere that would be a direct replacement.
    Did you unplug the high beam wire? So that if you clicked your switch to high beam your headlight would turn off?
    I had to put in a additional switch to turn off just the headlight.
    South Florida
    14
    Quote Originally Posted by Rich View Post
    Rich -Thank you for the info on the tire. Yes I did unplug the high beam wire. I didn't really no what else I could do. What type of switch did you install
    Member xzyfsk's Avatar
    Nov 2010
    Fortville Indiana
    81
    The stock tires will not take a plug. They are just too thin between the knobs. I just had a flat from a thorn. Tubes are very easy to fix. Just take the time to practice som at home to get a comfort level.
  1. Nuetech TUBliss tubeless tire thing
    By Skyking in forum Performance and Customization
    Last Post: 11-24-2012, 11:16 PM
  2. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 11:52 PM
  3. A three-position headlight switch - Low-High-OFF
    By Rohnsman in forum Technical Help
    Last Post: 10-19-2011, 01:43 PM
  4. Tubeless tire and headlight switch
    By pumpgear in forum General Discussion
    Last Post: 12-30-2010, 06:54 AM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 07:50 AM
