New owner, oil in air box normal?
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By scotti158
Thread: New owner, oil in air box normal?
    Junior Member gintaras's Avatar
    Jun 2014
    7
    Picked up a '96 TW with 3200 miles on it.
    First thing I did was adjust the valves, oil change with Mobil-1 10w-40 MC Synthetic, spark plug, and then air filter.
    When I removed the filer cover, I'd say at least a half quart poured out of it, is this normal?
    I cleaned it all out and washed the air box, installed a new filter and proceeded to take it out and get muddy, so much fun!
    It sat overnight, and I removed the cover to see if any oil was in there, and sure enough, oil dripped out and the bottom 1/2" of the filter was saturated, is there something that I should look for? Or is this normal?
    This thing is a blast, it'll do 65mph.
    Jun 2014
    7
    Oh, and the oil level is normal, it is just shy of the upper line when the bike is level.
    May 2013
    Groton, NY
    2,663
    Are you checking the oil when it's on the side stand or are you holding it vertical when you check it? It should be held vertical. I usually keep my level in the middle of the window to avoid oil in the air box. A lot of wheelies will cause this also.
    Zack likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member indika666's Avatar
    Dec 2013
    Colombo, Sri Lanka
    109
    nope..! that much oil in the air box is not normal..!
    Too much oil in the crankcase??
    Check the oil level when bike is vertical as " scotti158" suggested..!
    2006 TW200E (JDM) -> 100% stock, Shinko SR428 front, Bridgestone TW204 rear, 14/45 stock gearing
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    How much oil did you put in when you changed it?
    Jun 2014
    7
    I put exactly one quart and a few splashes to get it up to level. I failed to check the level that the PO had it at, but I'm suspecting and hoping that he just put too much in it.
    Dec 2013
    Colombo, Sri Lanka
    109
    Quote Originally Posted by gintaras View Post
    You drained all the oil before adding your one quart, i presume?
    So there should be no oil when you check again right? (or less oil)
    Jun 2014
    7
    Quote Originally Posted by indika666 View Post
    Yes, of course. And that's the thing, even though I did not overfill it, there was about 1/4" of oil in the air box after I cleaned it.. I'm thinking it could have been residual.. I guess I'll just keep an eye on it, thanks for the replies.
    Frosty Hollow
    13,059
    This seems to be a somewhat of a problem from time to time. A fellow I ride with occasionally ride with had the "oil in the airbox" issue. Unfortunately, after he cleaned out the oil, I don't know if the problem surfaced again or I'd tell yet what the answer was/is.
    In addition to the help/suggestions others above have been giving you, here is how to google search the TW forum better: site:tw200forum.com tire size. Replace the words "tire size" with something like "oil in airbox". It should give you a few forum posts in the past in which to search similar problems you have.
    I wish I could give you an exact cause to your problem, but if you read some of the posts from the search, it may lead you in the right direction.
  1. Replies: 9
    Last Post: 05-22-2014, 05:15 AM
  2. Is this normal?
    By Dino171 in forum Technical Help
    Last Post: 05-30-2012, 06:59 PM
  3. Just so you're smarter than normal
    By qwerty in forum Off-Topic
    Last Post: 01-27-2012, 11:44 PM
  4. 87- Strange symptom or normal
    Last Post: 03-13-2011, 06:14 PM
  5. New Owner, Young Owner
    By Justin5117 in forum Performance and Customization
    Last Post: 11-06-2010, 03:58 AM
Tags for this Thread
