Cam Chain Tensioner
Results 1 to 8 of 8
    Member roamineye's Avatar
    36
    Hi, folks - I'm a new TW owner as of 27 Dec, and have a couple of question for the experts:
    What's the procedure for adjusting cam chain tension?
    There's a metal bracket mounted under the bike between the back of the crankcase and the front of the swingarm on a cross brace. It has a tubing barb on it, but the metal "tube" appears to be solid. What in the world is it, and what is its function? I believe it had a short piece of plastic tubing on it, about 2" long, that didn't connect to anything else. I think I knocked it off while wiping excess grease off after greasing the swingarm.
    Several searches in this forum haven't yielded any help.
    Thanks in advance!
    1988 Yamaha TW200
    2007 Honda ST1300A
    2008 Suzuki DR650
    Desert, SoCal
    7,369
    The j-tube is for the carb vent. It's supposed to have another piece of tubing on the south end of it, but no one's ever seen one cuz they fall off 10 miles from the showroom. Without it the j-tube traps water and causes stalling. I ditch it and end the vent tube a few inches above it, in the motor's wake.
    36
    Thanks - I'll have to have a look at my vent tube. Not sure where it is right now!
    1988 Yamaha TW200
    2007 Honda ST1300A
    2008 Suzuki DR650
    36
    Anyone have any ideas on the cam chain tensioner?
    1988 Yamaha TW200
    2007 Honda ST1300A
    2008 Suzuki DR650
    Desert, SoCal
    7,369
    Quote Originally Posted by Roamineye View Post
    Service manual. Section 3, page 5. Download info on the site.
    36
    Thanks - appreciate all the support
    1988 Yamaha TW200
    2007 Honda ST1300A
    2008 Suzuki DR650
    Senior Member sinophilia's Avatar
    Aug 2010
    Verona, Italy
    522
    You can also adjust the tensioner with the engine running - this way you will see the rod moving in and out, you can adjust it so that you can feel it with your finger.
    Red Max - 1996 TW200 - 14/45, 320mm toothed brake disc, X-Racing titanium exhaust, Ricochet skid plate, Mule hitch pins, large pegs, VeeRubber VRM274&275 tires
    36
    Thanks - downloaded the maintenance manual and got it done with no problems. Also checked valve lash, but the bike has only 1350 miles on it, and no adjustment was necessary. Rough idle and inconsistent idle speed is still an issue. I'm running some sea foam in the gas and this has helped, but I think I'll end up pulling the carb and inspecting it.
    1988 Yamaha TW200
    2007 Honda ST1300A
    2008 Suzuki DR650
  1. Chain
    Last Post: 07-25-2012, 09:32 PM
  2. aftermarket chain guide/tensioner?
    By Point37 in forum Technical Help
    Last Post: 04-27-2012, 08:36 AM
  3. Should I get a new chain if so what
    By Stromper in forum Performance and Customization
    Last Post: 01-24-2012, 06:23 AM
  4. Checking new style timing chain tensioner
    By RockyTFS in forum Technical Help
    Last Post: 05-16-2011, 05:27 AM
  5. help chain
    By Logan in forum General Discussion
    Last Post: 01-25-2011, 09:18 AM
1988 yamaha tw200 timing chain and tensioner
adjust chain tension tw200
how to adjust the cam chain on a 90 tw200
tw200 cam chain adj
tw200 cam chain adjustment
tw200 cam chain tension
tw200 cam chain tensioner
tw200 chain tensioner
tw200 timing chain adjust
tw200 timing chain adjustment
yamaha tw200 cam chain tensioner
yamaha tw200 manual cam chain tensioner adjustment
