Handlebars I need help
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By docjekyll2002
Thread: Handlebars I need help
    Jun 2014
    Bel Air Maryland
    4,169
    I was hill climbing and dropped my TW. The stock handlebars got bent and it didn't take much. I would like to purchase a stronger handlebar. Anyone have a part number of the Renthal bars that would be close to stock.
    Senior Member docjekyll2002's Avatar
    Aug 2013
    648
    Not sure how strong Flexx handlebars are and if their adapters fit the TW but they are around $300 and reduce arm fatigue on bumpy trails. I would invest in aftermarket products that do a better job than stock parts if i can afford it
    Fred likes this.
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    229
    pro taper are 70000 psi under custom see the best handle bars
    see THREADS at the bottom of this page
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
    Aug 2011
    Cayce, SC
    3,109
    Anytime something fails I see it as a chance to upgrade. Renthals and Protaper are great upgrades. Whatever bend fits you best but I really enjoy my atv hi bars on the tw. Unless you are really short the standing position on the tw leaves alot to be desired. Just food for thought...
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    18,694
    If you can't afford Flex then simple riser extensions add a bit of buffer to absorb some of the destructive energy in a crash. Unless you are Japanese short I would recommend the riser extensions just for comfort while standing.
    Senior Member gamorg02's Avatar
    May 2014
    Central NY
    174
    i always go back and forth upgrading stock bars on dirtbikes to something stronger, always afraid in a hard enough dump, something more expensive will break instead of the bars being bent.
    that being said i'm not often out in the wilderness like you folks might be, more in trails that are no more than a couple miles from a road.
    Senior Member Bruce's's Avatar
    May 2014
    258
    I just replaced my bent stockers for a set of renthal 971 bars I had in the shed .They are pretty much a dead match for the stockers in every way except there is no crossbar which I didn't want anyway .
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by greenbomb View Post
    Thanks I'll check them out
  1. Handlebars-what's your favorite?
    By littletommy in forum Other Bikes
    Last Post: 05-23-2014, 07:51 PM
  2. Banshee Handlebars
    By Kirk Ross in forum Performance and Customization
    Last Post: 02-28-2012, 06:17 AM
  3. Handlebars
    By TeeDubs in forum General Discussion
    Last Post: 01-27-2012, 07:47 PM
  4. Handlebars
    By Lido in forum Technical Help
    Last Post: 10-13-2011, 09:32 PM
  5. new handlebars
    By 805gregg in forum Performance and Customization
    Last Post: 11-19-2010, 06:11 PM
