Clunk
Results 1 to 4 of 4
Thread: Clunk
    Senior Member 1RobAusdemore's Avatar
    May 2014
    Twin cities
    182
    Clunk
    I purchased a 92 with ten thousand miles on it. I don't know any maintenance history of the bike other than was told of an top end rebuild around 8,000 miles. Anyways it runs good but I am pretty sure it needs a new steering head bearing, and the clutch seems tired. I have never messed with a clutch except cable adjustments, and never really dealt with diagnosing a problem other then to let it cool down because I was working it too hard trying to get up a hill(previous bikes).
    So it seems slow to engage after shifting followed by a clunk. I usually let off the gas shift then let out the clutch wait a second then give it gas again, when shifting under power it works just doesn't seem quite right to me. The problem is apparent when dropping the clutch to clear a log or something like that. It just doesnt snap the front tire up like I would think it should. Where do I start? Any help would be appreciated.
    Senior Member 50short's Avatar
    Aug 2013
    Excelsior, MN
    287
    What oil are you running? Is the clutch actuator return spring seated properly...there are a lot of threads about this easy fix. Not sure what the clunk is coming from. It could be a worn shift drum of shift forks. Someone must've run it low on oil to warrant a new top end at 8k miles. Could damage the transmission I suppose.
    God willin' and the creek don't rise.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Besides what 50short advised , there are lined-up marks on the actuating lever and the case down where this spring is located ( shifter side of the case) . I've read there is also an adjustment on the inside of the right case ,where the clutch plates are ( rear brake side). Is the clutch cable stretched?.
    May 2014
    Twin cities
    182
    I changed it with Mobil 1 4T, I haven't checked the outer adjustments yet, but I will this weekend, it sounds and feels internal to me, what are symptoms of worn clutch plates and springs. Shift forks sound complicated and expensive. I don't think the cable is stretched.
  1. Clunk from instrument panel at every bump?
    By PalmStateCrawler in forum Technical Help
    Last Post: 11-07-2017, 04:47 AM
  2. Clunk and Lunge into 1st..
    By Sferics in forum Technical Help
    Last Post: 04-12-2012, 04:38 PM
  3. front shock has developed a "clunk"
    By misterpepper in forum Technical Help
    Last Post: 10-02-2011, 04:02 PM
  4. Loud clunk when down shifting
    By moneal in forum Technical Help
    Last Post: 06-28-2011, 12:04 AM
