How To Remove the Pilot Screw?
Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By TW-Brian
  • 3 Post By swmotdub200
Thread: How To Remove the Pilot Screw?
    Junior Member ccryder125's Avatar
    Jun 2014
    7
    Talking How To Remove the Pilot Screw?
    Hi everyone,
    Thanks in advance for anyone who can help me. I am new to the TW but had bikes all my life. I just sold my DRZ 400s to get a TW and scored on a 2003 with 207 miles on it. It has sat for the last 8 years in a crate and is in great shape but needs the usual to get running.
    I have dismantled the carb and purchased a rebuild kit and everything looks good, except I cannot figure out how to remove the pilot screw. What I am referring to is here https://tw200forum.com/forum/technica...-cleaning.html called the pilot screw.
    On my carb, there is a silver cap with a paper clip sized hole in it over the hole where the pilot screw sits. I can't figure out how to remove the cap? I have seen pictures of the cap and it looks like it is a threaded screw? I can't find anything on how to remove it. Has anyone dealt with this? Does it matter if I just mangle the cap and remove it for good?
    I have cleaned and replaced all the parts in the carb minus the pilot screw and feel like I need to do it. The valve seat was very stuck in place and so I figure the pilot circuit is gummed up as well.
    Thanks for any help!
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Thread a drywall or self tapping screw into the plug and pull, it'll come right out.
    Jun 2014
    7
    I am an idiot. Thank you! Do I even need the cap?
    Pleasanton, CA
    5,720
    Quote Originally Posted by ccryder125 View Post
    Nope, toss it.
    p.s. Welcome to the forum!
    KingVolcano likes this.
    Junior Member swmotdub200's Avatar
    Jun 2014
    4
    No, you should not need to replace it. Take care when removing the screw because there will be a tiny O ring, washer, and spring on it. If your carb. is varnished up they may remain up in there until you hit it with carb cleaner, sending them into the farthest corners of your shop. Don't ask how I know this Good luck.
    Senior Member 1RobAusdemore's Avatar
    May 2014
    Twin cities
    182
    Quote Originally Posted by swmotdub200 View Post
    Good advice!
    Jun 2014
    7
    Thank you everyone for the quick replies and help, I really appreciate it. This forum is so sweet! Such a wealth of knowledge. I will post some pics of my bike soon.
  1. Pilot screw extension $30
    By gregor in forum TW200 Classifieds
    Last Post: 09-27-2013, 08:39 PM
  2. Pilot Screw Adjustment Help
    By bodhi4 in forum Performance and Customization
    Last Post: 03-22-2013, 02:33 PM
  3. Pilot screw set
    By dantilghman1 in forum Technical Help
    Last Post: 01-25-2013, 11:05 AM
  4. pilot/air screw
    By PalmStateCrawler in forum Technical Help
    Last Post: 06-04-2012, 08:27 AM
  5. Pilot Jet Screw Closed
    By JD_ in forum Technical Help
    Last Post: 04-11-2012, 08:32 AM
1999 tw200 how to remove pilot screw
drz 400s carb pilot screw pic
how to remove drz pilot jet
pilot screw adjustment teikei tw200
teikei carburetor tw200 pilot screw cap
tw200 carb pilot screw
tw200 no pilot jet adjustment
tw200 pilot jet photos
tw200 pilot screw
tw200 pilot screw set
what does the yamaha tw200 carburator pilot screw do
Tags for this Thread
