Bought a 1990 with only 2000 miles but clutch clearly slips
Results 1 to 10 of 19
Like Tree2Likes
Thread: Bought a 1990 with only 2000 miles but clutch clearly slips
    Junior Member reef's Avatar
    Jun 2014
    Halifax , Nova Scotia , canada
    12
    Unhappy Bought a 1990 with only 2000 miles but clutch clearly slips
    Any thoughts folks?
    I am going to change the oil asap just in case the guy used car oil instead
    But any feedback would be appreciated
    My wife likes the bike and doesn't want to see the bike go
    It was 1850 dollars so it wasn't a massive amount of money but the bike is dangerous if the clutch doesn't hook up well
    Senior Member Bruce's's Avatar
    May 2014
    258
    How was the adjustment ? Even if the clutch plates are burnt ,it doesn't cost much to replace them and be good again so no need to sell it .
    KingVolcano likes this.
    Jun 2014
    12
    Thnx for the prompt reply
    Could it be it has car oil??
    Jun 2014
    12
    And what do you mean by adjustment?
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    There is an adjustment on the clutch cable at the lever and there is also one at the engine. The adjustments will determine when the clutch engages. If it is at the end of the adjustment it may be slipping and may need minor tweaking to get better. If it ran with an oil not made for wet clutches it could definetly slip. You may get lucky and just get by with an oil change using proper oil. If that doesn't work just change the clutch plates, it's not too bad of a job if you read up about it here and take your time.
    Jun 2014
    12
    The clutch engages way at the end
    I will adjust that ASAP and report back
    Thnx a million for the help folks
    Will keep the thread updated
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    229
    [QUOTE=reef;126121]Any thoughts folks?
    Yep[ Your age / Mechanical ability .? Had any other motorcycles ? Why is a slipping clutch dangerous ? Is it your wife's bike?
    There is also an adjustment inside the side case that makes up, for wear / almost always needs heavier springs at about $15 if the plates are not worn to bad . These are not Motocross machines. They are TRAIL bikes and should be treated like trailbikes
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
    Jun 2014
    12
    Good God. That clutch adjustment made the bike feel like it got 100cc more engine
    Goes properly now.
    I hope it stays like that for a while.
    Jun 2014
    12
    Now what could be the deal with the starter. When the bike is not running (engine that is) i hit the starter and nothing happens. Kickstand up, bike in neutral, and clutch in, just in case they built any safety settings into it.
    However when the bike is idling and i hit the starter button there is a faint buzzing sound from the starter (i presume)?
    Any thoughts on what this could be?
    May 2014
    258
    It's hard to diagnose electrical issues from here ,but start with the basics .Check the battery condition and charge ,check the connections ,get a test light or a meter ,look at the wiring diagram and start checking things out .You might want to try jumping the actual starter as well as it's possibly seized up or who knows from not being used much .
  1. 2000 TW Clutch Won't Disengage
    By padillamia in forum Technical Help
    Last Post: 05-28-2014, 09:38 AM
  2. 1990 Tw200 for sale 1300.00 2500 original miles
    By HDLLLIII in forum TW200 Classifieds
    Last Post: 08-14-2013, 07:27 PM
  3. My new obsession/ 1990 w/ 488 miles
    By dreynolds in forum General Discussion
    Last Post: 05-03-2013, 03:12 AM
  4. 2006 TW200 3,525 miles $2000 SOLD
    By FredGarvin in forum TW200 Classifieds
    Last Post: 03-11-2013, 07:13 PM
  5. 2007 FOR SALE $3,450 with 2000 miles
    By Matthew Rowland in forum TW200 Classifieds
    Last Post: 06-20-2012, 05:51 AM
