Lifting TW
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Like Tree75Likes
Thread: Lifting TW
    Member c.salt's Avatar
    Jun 2014
    39
    Lifting TW
    Hello
    Just got done tightening my chain. Used a floor jack and a piece of 2x4 to lift the rear wheel. Pretty unstable.
    Wondering what others have come up with for a more stable platform to work on bike.
    And also would like to know if anybody makes a center stand that fits a TW?
    Thanks
    Member n9znd's Avatar
    Apr 2014
    North Central Indiana
    49
    Get a old milk crate and attach a smooth top and there is your stand. That is what I use. Jim
    SickPuppy76 likes this.
    Jun 2014
    39
    Have set a 2x8 on top of a milk crate to work on a honda crf 150 and broke the milk crate. The tw is quite a bit heavier. Looking for some good ideas for not a lot of money. I guess its time to break out the skill saw
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    I like TWBrian's approach, see post #3. Here's another good low buck approach. See post #2.
    Senior Member gamorg02's Avatar
    May 2014
    Central NY
    174
    rear paddle stand for rear work is great but font fork stands don't really work on the front so i use a standard 1500 lbs atv jack to lift the whole thing up when needed. I put a 2x4 on its 2" side and the other rests right infront of the starter motor. pretty stable with a strap around it.
    Apr 2014
    49
    The Milk Crates that my uncle always used BITD was made out of metal. They are hard to find. The one I am using is for filing paperwork, pretty heavy duty. I think a cheap plastic one would break for sure. Jim
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Just make sure you check the chain tension with the rear wheel on the ground, not in the air.
    B-dub and gamorg02 like this.
    Sep 2011
    Southcoast MAsshole
    2,661
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Harbor Freight MC / ATV lift ( Yellow in color ) , works ( just barely ) on my Shadow RS750 too .
    LuvNot likes this.
    Senior Member arrowsmith's Avatar
    Missouri
    673
    I use a floor jack with a board on it. I put a strap on each side of my rack to something heaver than the TW.
lift stands for yamaha tw200
redline mx1 motorcycle lift
tw200 stand work
