Bike idles like a dream but splutters and dies on open throttle???
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Like Tree2Likes
Thread: Bike idles like a dream but splutters and dies on open throttle???
    Junior Member kemp.darryl's Avatar
    Mar 2014
    Ponta Malongane, Mozambique
    12
    Hello everyone
    Am i correct in saying: If my bike was running like a dream on a long sandy road and then wala, out of the blue she cant open throttle past idle because she stutters and quits. Whoever always returning to a perfect idle.
    1. i inserted a new globe for the headlight 3 days prior
    2. I filled a half a tank of gas the previous day
    Should i start with changing the fuel and then carb?
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Has the bike been sitting without running for long? Did you recently fill it up with gas? Sounds carb related to me. Will it get past the stumble and run OK at high revs?
    Spokane, Washington
    17,291
    Lucus Deep Creep Fuel Cleaner or Seafoam
    3oz for the tank.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    I recently struggled with the same thing. It was running rich and stumbling at about 1/4 throttle. I removed the carb and checked everything out. After installing, it did the same thing. I had great spark at the plug but it was black and sooty.
    It ended up being a mouse nest in the airbox slowing airflow. Stinking mice.
    I'd pull the plug and see what color the ceramic is. If it is black, you are either getting too much fuel or not enough air.
    Let us us know what you find. Good luck!
    Senior Member docjekyll2002's Avatar
    Aug 2013
    648
    Mine was lugging around yesterday and then the bike kept dying when i opened the throttle. Thought i was gonna push my bike all the way home. I opened the airbox cover up and saw a white paste at the bottom. Also the yellow plastic contaminant/excess tube behind the carburetor on the left side of the bike was full of that paste. Apparently i sprayed too much air filter oil on the foam. I decided to give her a good rinsing so it's mostly water now and squeeze excess out. Hopefully she runs better.
    Feb 2013
    Iowa
    264
    Sounds like that should help.
    Aug 2013
    648
    Even after cleaning the air filter foam, the bike is still lugging and dying. I think i might not have seated the cam chain tensioner after inspection and the spring is still compressed all the way. I will check that and also flip the intake valve cover upside down as i see the inside shape is assymetrical. I hate myself for tinkering with the engine when nothing was broken
    Feb 2013
    Missoula, MT
    908
    Quote Originally Posted by docjekyll2002 View Post
    Did you recently adjust the valves? One time, I had one of the lock-nuts come ALL the way off the adjuster on the exhaust valve. The bike ran but not very well.
    Aug 2013
    648
    Quote Originally Posted by fishguy View Post
    Yikes. Yes i did recently adjust the valves. I found the exhaust locknut had loosed halfway up the adjuster. I readjusted my valves today and made sure to tighten the locknuts real tight. I checked the cam chain tensioner and did an oil change. Tapping noise still present
    Feb 2013
    Missoula, MT
    908
    My '95 has "loud tappets". I refurbished a '98 and it was VERY quiet. Most here report that this engine (at least the early years) is noisy. The '98 had 6000+ miles, my '95 has 3400+/-. I think they quiet-down as they age. How many miles on yours?
  1. engine starts with electric start, dies with throttle.
    By mc_lamma in forum Technical Help
    Last Post: 04-21-2013, 01:49 PM
  2. engine hesitating with throttle slightly open?
    Last Post: 11-25-2012, 04:30 PM
  3. idles fast then dies
    By carp123 in forum Technical Help
    Last Post: 09-25-2012, 09:41 PM
  4. Bike idles fine on stand, dies when upright
    By Sloppy in forum Technical Help
    Last Post: 07-07-2011, 07:28 PM
  5. TW200 Idles and Dies
    By Quicksand in forum Technical Help
    Last Post: 10-22-2010, 03:57 PM
my motorbike splutters along
