Ignition switch: 1987-2000 vs 2001-201x
Results 1 to 10 of 10
    Junior Member NormSash's Avatar
    Mar 2011
    14
    Here are the part numbers for the TW200 ignition switch:
    1987-2000 YAMAHA TW200 TW 200 IGNITION SWITCH MAIN KEY LOCK 2GK-82501-01-00
    2001-2011 YAMAHA TW200 TW 200 IGNITION SWITCH MAIN KEY LOCK 5LB-82501-01-00
    The newer switch is somewhat cheaper than the older model switch (< $50 cheaper.)
    Does anyone know what changes were made to the switch and can I use the newer model switch on an older (1995) TW?
    Anyone have a used one for sale?
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    The newer switch has a different plug to the wiring harness. They are not the same.
    Mar 2011
    14
    Thanks Leben... I do see that the older model switch has a 3-pin connector with an additional pigtail wire. The newer model switch has a 4-pin connector with no pigtail wire. I'm thinking that the physical switch would work and that I would need to splice the wiring to make it work.
    Senior Member andy10889's Avatar
    Jan 2014
    Mobile, Al
    145
    That is correct, operation is the same.
    Apr 2013
    385
    i think you could swap the bottoms over from barrel to barrel that way you wouldn't have to cut any wires, i did try to splice the wires from old to new but cannot remember just now what wire was what, i will have a look tomorrow
    also the newer models connect under the seat ..old one behind the headlight cowel
    Senior Member Zack's Avatar
    Apr 2014
    Oriani Haiti
    185
    Here is the function of the two switches. Sorry for the bad quality, but as you can see, the function is definitely different, unless I'm not understanding it right. The first diagram is for the 1987-2000, and the second is the new, current style.
    B = black
    R = red
    Br = brown
    R/W = red/white
    B/W = black/white
    L/Y = blue/yellow
    L/B = blue/black
    Zack
    Mar 2011
    14
    Hi Zack... I noticed the difference in function also via the wiring diagrams by ValorSolo here https://tw200forum.com/forum/technica...tml#post129360.
    The wiring images that you provided... were they out of an official service manual or were they from ValorSolo's thread. The reason I'm asking is to figure out if there was actually a functional change, or if possibly ValorSolo made a slight mistake when drafting the diagrams.
    Mar 2011
    14
    Hey supachip1... swapping out the bottoms is a most excellent idea! I never thought of that, but it is certainly possible to take the switch base off (I already did it to clean out some corrosion. I'm guessing that the mounting holes are in the same location (hoping is more like it), and then the bases should be able to swap and no rewire needed!
    Apr 2013
    385
    the ignitions are physically the same size n shape..just the wiring is different..so if you swap both the bottom part with the wires soldered onto and the plastic connection part that is attached to the bottom of the key barrel then it should work…
    Apr 2014
    Oriani Haiti
    185
    Normsash, sorry I didn't see your post earlier. Yes those pictures were out of official manuals. I think ValorSolo got it right.
    Zack
  1. Ignition switch
    By Kama'aina in forum Technical Help
    Last Post: 05-09-2014, 04:28 PM
  2. Ignition switch
    By TheSchreibs in forum Performance and Customization
    Last Post: 04-02-2014, 05:59 AM
  3. ignition switch
    By easternfrontnh in forum General Discussion
    Last Post: 03-19-2013, 02:13 AM
  4. In need of tw ignition switch and key
    By andrewsclues in forum TW200 Classifieds
    Last Post: 10-15-2012, 07:01 PM
  5. WTB Ignition switch
    By brownie2 in forum TW200 Classifieds
    Last Post: 10-04-2010, 09:23 PM
1987 yamaha tw200 ignition switch
2001 yam tw 200 ignition switch main key lock 5lb-82501-01-00
how to connect a different ignition key switch in yamaha tw1994
ignition switch 5lb-82501-01-00
main switch steering lock 2gk82501-01-00
tw 200 ignition switch for sale
used 2001 tw200 main switch steering lock 5lb-82501-01-00
yam 2001 tw200 2001-2011 yamaha tw200 tw 200 ignition switch main key lock 5lb-82501-01-00
yamaha tw 200 main switch 5lb-82502-01-00
yamaha tw200 ignition switch diagram
yamaha tw200 main ignition switch
Tags for this Thread
