Chain length question
Results 1 to 8 of 8
    Junior Member wyelkhunter73's Avatar
    Jul 2014
    Not sure what area to put this in but here it goes. I am going to put a 55t sprocket on my bike. I was wandering what length chain I am going to need since I am going up from 50t sprocket?
    thanks.
    Jul 2014
    never mind I just found the chain length calculator.
    Junior Member Bensjammin66's Avatar
    Jul 2014
    3
    Quote Originally Posted by wyelkhunter73 View Post
    I have looked around on this forum and im sure its every where but i cant find it and need chain help. I want to do a 14/47 on my 2002 TW200 for a little more road top end. I have used the chain calculator and they say the 14/47 should be a 116 link if the stock one was 122. Then im looking at ebay non o-ring kits and they are listing 120 links not 116 with a 14/47 kit. Which is right?
    I just want an o-ring chain with 14/47 sprockets. Click and buy. Can someone help me out with a link or some helpful info?
    Senior Member Padilen's Avatar
    May 2014
    Cadillac Michigan area
    1,598
    Chains come in certain lengths. Not exact for all applications. So if exact link chain is not available it's best to buy a longer chain.Then "break" chain and remove extra links. Buy a chain shorter and you'll be adding extra links and master links to make it long enough. Not recommended.
    Check out Procycles web page.
    Jul 2014
    3
    Quote Originally Posted by Padilen View Post
    That makes sense, do you turn the adjuster all the way in and then remove links to fit? Sorry. First TW, first motorcycle at that. Total Newby here.
    May 2014
    1,598
    You could. But I'd get an idea of how many links first. Would suck to buy a long enough chain then remove to many links.
    My last chain change was in the late 80's-early 90's. Then I rarely rode my IT's. Until my TW I've been riding a shaft drive for 20 +years.
    Jul 2014
    3
    how do i know how many links the 14-47 will need? was kinda hoping someone could chime in who had it. 14-47 seems to be a decently popular gear for these. I was told this is stock - OEM Sprockets Front-Rear: 14-50
    OEM Chain Pitch-Links: 428-122. If i had to guess, 120 is what id end up needing?
    May 2014
    1,598
    Well Procycles says 120 "might" fit so hopefully someone who has changed sprockets will chime in.
    Might should woulda coulda. Doesn't seem absolute to me.
  1. Replies: 5
    Last Post: 01-01-2016, 12:15 PM
  2. Sprocket/chain length calculator
    By goldenhtr in forum Technical Write-Ups
    Last Post: 04-20-2014, 09:47 AM
  3. Chain Length
    By Rainman in forum Technical Help
    Last Post: 11-30-2012, 09:36 AM
  4. Chain length?
    By Roninboise in forum Technical Help
    Last Post: 02-09-2012, 08:26 PM
  5. chain question
    By muliefever in forum Technical Help
    Last Post: 04-08-2011, 12:32 PM
