Warning: Do not exceed 55mph!
Page 1 of 13 12311 ... LastLast
Results 1 to 10 of 130
Like Tree72Likes
Thread: Warning: Do not exceed 55mph!
    Member Grimmtastic's Avatar
    Mar 2014
    Canton, OH
    63
    If you run your TW over 55MPH your valves start to float due to the piss-pore Yamaha design of cutting corners and using weak valve springs. I just scattered my engine at 70mph. Broke exhaust rocker, bent valves and trashed the piston. Don't know if Yamaha is gonna warranty the rebuild. HEY YAMAHA, IF IT'S NOT SUPPOSED TO BE RIDDEN OVER 55MPH, LIMIT THE F*****G REVS!
    snacks91 and acekool like this.
    Ride it Like you Stole it!
    Apr 2011
    Martinsville Indiana
    2,089
    Sounds like something was wrong with it. They usually hold up to wide open throttle for thousands of miles. Valve float is basically a rev limiter on these engines
    littletommy, Fred and williamemack like this.
    Spokane, Washington
    17,284
    First time I've heard of someone blowing up their TW.
    Quote Originally Posted by small's View Post
    Fred and Bagger like this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    what year and how many miles when it broke?
    Mar 2014
    Canton, OH
    63
    2013 bought with 0miles March 31st 2014 now has 2600miles
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    503
    warranty! Make sure you get a loner too
    SeatConcepts,carb mod,Shinko tires,15/50 o-ring chain,custom racks f/r, aluminum luggage,windshield,handguards,heated grips,Clarke tank,high frt fender,led running lights,folding shifter, wide pegs,12v outlets,headlight kill switch,voltmeter,stainless header,2nd brakelight,GPS/phone mount
    Member Oldad's Avatar
    Apr 2013
    Shawnee National Forest (Harrisburg), IL
    85
    Sounds like you got your wish. You can put a WR250 motor in it now.
    https://tw200forum.com/forum/performa...ne-swap-8.html
    Hoot Gibson, joeband and NavyChief like this.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Quote Originally Posted by tinman tim View Post
    +1! I flog mine at WOT with no problems so far, (knocks on wood...).
    Fred likes this.
    Apr 2014
    Dryden NY
    6,338
    Quote Originally Posted by Grimmtastic View Post
    If you run your TW over 55MPH your valves start to float due to the piss-pore Yamaha design of cutting corners and using weak valve springs. I just scattered my engine at 70mph. Broke exhaust rocker, bent valves and trashed the piston. Don't know if Yamaha is gonna warranty the rebuild. HEY YAMAHA, IF IT'S NOT SUPPOSED TO BE RIDEN OVER 55MPH, LIMIT THE FUCKING REVS!
    I am sorry to hear about your motor. Mine is a 2013 as well and swear at "60mph on the speedo" that equates to about 57mph in real life my engine sounds like it is going to rattle to pieces. I only weigh 165 and have broken it in responsibly. I do not think my engine will last one year the way it sounds.
    Tom
    Apr 2011
    2,089
    It should be ook as long as you dont run it low on oil. There are a handful of guys on here with 40-50,000+ miles without a rebuild yet.
    littletommy, Hoot Gibson and troll like this.
  1. low rpm idling when warning up
    By Schmitty in forum Technical Help
    Last Post: 03-30-2014, 08:10 AM
  2. What is a good Chain sproket set-up for 50-55mph?
    By sasnydley in forum Technical Help
    Last Post: 10-03-2011, 03:23 PM
  3. Public Warning - Cadbury`s Chocolate
    By Petrus in forum Off-Topic
    Last Post: 10-21-2010, 09:40 PM
  4. Riding @ 55mph fine....then just died. Now what?
    By adavis in forum Technical Help
    Last Post: 08-25-2010, 08:11 AM
  5. SoCal to Seattle: 1200 miles at 55mph with stock gearing?
    By tltmts in forum General Discussion
    Last Post: 08-17-2010, 09:12 AM
1974 cusman truckster valve clearances
27 hp 3w cushman truckster valve adjustment
hyper miler does not exceed 55 mph
tw200 redline
tw200 rpm at 55mph
