carb question - flat spot at mid-rpms high gear
Results 1 to 5 of 5
    Senior Member gamorg02's Avatar
    May 2014
    Central NY
    174
    Not used to running 200cc bikes on the road. Anyways, i've noticed (mostly in 5th gear) that about 5500-6000 rpms if i'm cruising it takes more 'throttle' than id' expect to speed up. like 1/3-1/2 throttle. I'm trying to figure out if maybe i'm a bit lean or if its just thats all the engine typically has at such a high gear/rpm.
    Instead of just 'speeding up', i've tried slowing opening the throttle and I do notice a *slight* change from enough to sustain speed to where i'll speed up, but it seems to be a bit of a spot in the throttle where it doesn't do much if its done quicker.
    Just looking for some feedback
    thnx!
    Jul 2012
    Wet-ern Washington
    1,409
    What year bike/carb, and what modifications have been made to it (if any)? Cleanings? Anything else of note, its been sitting or it runs daily, any other work done? You get the idea.
    - Leisure Time Larry -
    May 2014
    Central NY
    174
    Quote Originally Posted by lrppcer View Post
    after i posted this i realized i didn't know, but should, and probably shoulda looked before I posted.
    stock exhaust/airbox. Haven't dug into the carb yet but PO said it was stock and he had cleaned it, runs fine otherwise.
    new plug, seafoam thru the tank.
    55 rear sprocket/14 front
    i guess i wanted to know first if its just kind of something you get used to running a 200cc on the street, but sounds like maybe not.
    '06 frame with carb
    I believe 99-2000 crankcase, early 80's cylinder YTM and I think 06 clutch/stator side covers with '06 electrical.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    IMO , the 55T rear sprocket may be the issue ?. OR , try rejetting , shim the needle ,and turn out the pilot screw and see what results you get .
    May 2014
    Central NY
    174
    Quote Originally Posted by frog13 View Post
    Its not the easiest to reproduce so I could try pulling the choke out a bit to see if is helped by going rich on the fly.
    why do you think the 55T?
  1. Carb high idle..could not having a chain cause this?
    By bluefox in forum Technical Help
    Last Post: 05-08-2014, 08:36 PM
  2. Question on high altitude jetting/operations
    By DaveyM in forum Technical Help
    Last Post: 07-21-2013, 09:45 AM
  3. high-temp gasket seal question
    By Point37 in forum Technical Help
    Last Post: 05-01-2012, 02:20 PM
  4. Carb/ high speed problems
    By reillyyz125 in forum Technical Help
    Last Post: 04-22-2012, 11:56 PM
  5. anybody try a flat slide carb. in the tw
    By dz1 in forum Technical Help
    Last Post: 05-29-2011, 06:17 AM
