Please help with flasher problem
Results 1 to 10 of 12
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    My right side turn signals work fine,but the left side just lights up but wont flash
    Can just one side of the flasher burn out?
    Checked bulbs , seem good...but thinking im just gonna replace all of them
    This is on my wifes 89 tdub
    Thanks for any help in what to look for
    Im just not sure if its a flasher,bulb or light socket problem???
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    The flasher operates for both left and right, are you sure the bulbs are good?
    Jan 2014
    New Jersey
    592
    The left side flashes if i keep tapping this part lightly with with the end of a flashlight handle while the left turn signal switch is engaged
    Also nobody seems to carry the bulbs with the original bulb numbers
    Would you know what bulb numbers i can use to replace the front and rears?
    Thanks so much
    rbm
    rbm is offline
    Jan 2011
    4,300
    That's the flasher. The bulbs should be 1156 for the rear and 1157 for the front unless yours are different from 2001+(which I don't think so).
    rbm
    rbm is offline
    Jan 2011
    4,300
    Try swapping the bulbs from one side to the other, if you have the same result there's an issue with your wiring.
    Jan 2014
    New Jersey
    592
    But isn't it weird that it starts to flash if I tap on the side of the flasher?
    rbm
    rbm is offline
    Jan 2011
    4,300
    Quote Originally Posted by Holdnon72 View Post
    It is odd, I don't have an explanation for that.
    Jan 2014
    New Jersey
    592
    Rbm...thanks so much!
    She's all fixed up now thanks to you!
    Bad connection up inside headlight cow where the grounds hook up...
    Thanks man!
    Senior Member docjekyll2002's Avatar
    Aug 2013
    648
    My left rear flasher wouldn't flash either a few weeks ago until i wiggled the cable where it starts going under the rear fender
    rbm
    rbm is offline
    Jan 2011
    4,300
    Thanks man!
    Glad I was able to help!
  1. solid state flasher for leds
    By mkriley in forum Technical Help
    Last Post: 08-26-2013, 06:34 PM
  2. Melted flasher relay....
    By rbm in forum TW200 Classifieds
    Last Post: 04-04-2013, 06:58 PM
  3. Flasher relay ID
    By chevyy1212 in forum General Discussion
    Last Post: 04-01-2012, 10:16 AM
  4. Led flasher
    By Paulp1 in forum Technical Help
    Last Post: 02-21-2012, 04:15 PM
  5. Will this brake light flasher work?
    By chevyy1212 in forum Technical Help
    Last Post: 01-22-2012, 10:27 AM
