Left side handlebar perch....
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By gamorg02
Thread: Left side handlebar perch....
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Can anyone advise, as to what size the left side handlebar perch screws are ?. . These are philips head screws and I would like to change them out to something less strippable . I'm probably going to have to use vise-grips or something else to get the upper one out ( yes , I even used a JIS screw driver !.) ,it's not stripped / rounded out completely .......yet , but I want to change these out before doom sets in .
    Senior Member gamorg02's Avatar
    May 2014
    Central NY
    174
    take a look here:
    HANDLE SWITCH LEVER
    you'll see those bolts are part #9, p/n: 98517-05020-00
    Secret on yamaha part numbers is the second 5 digits. the first two is the bolt diameter (5mm) and the last 2 are the length (20mm). Then you just use the standard pitch sizes:
    4mm = .7mm pitch
    5mm = .8mm pitch
    6mm = 1 mm pitch
    8mm = 1.25mm pitch
    I forget what 3mm is offhand but its standard throughout (.5 or .6mm pitch IIRC). 10mm starts going back and forth between 1.25 and 1.5 mm pitch depending on the application.
    hope that helps.
    old white truck likes this.
    Jun 2011
    SW, Ohio
    2,518
    Much appreciated !!!!.
  1. ***FOUND***WTB left side (stator side) case for a 1996.
    By Pelon in forum TW200 Classifieds
    Last Post: 07-21-2014, 11:37 AM
  2. Problem with turning signals / left handlebar switch issue?
    By elasmomark in forum Technical Help
    Last Post: 01-01-2014, 11:23 AM
  3. WTB left side cover
    By vanillagorilla1 in forum TW200 Classifieds
    Last Post: 12-29-2013, 08:36 PM
  4. Left Side engine cover help please...
    By tcepilot in forum Technical Help
    Last Post: 09-08-2013, 06:22 PM
  5. WTB left side panel
    By brownie2 in forum TW200 Classifieds
    Last Post: 10-07-2010, 06:10 AM
