Messed up front sprocket install need help
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree1Likes
Thread: Messed up front sprocket install need help
    Senior Member 1RobAusdemore's Avatar
    May 2014
    Twin cities
    182
    Ok I put on a new sprocket and chain and did not install the sprocket correct. I only drive it a couple of miles and took the cover off for a different reason and noticed this.image.jpgimage.jpg
    May 2014
    Twin cities
    182
    The screw heads are ground almost off. I can slide the sprocket back and forth on the shaft.
    Apr 2014
    Dryden NY
    6,336
    what is the picture trying to confer? I see nothing wrong.
    Tom
    Senior Member Dubzha's Avatar
    Aug 2013
    Twin Cities, Minnesota
    385
    Is the keeper plate damaged? That's supposed to keep the sproket in place, although not in an exact position. Not a good situation. If the plate isn't damaged, could the small bolts have sheared off? I know the plate and sprocket have to stay together or the sprocket will 'wander'.
    What part of the Twin Cities are you in?
    ~ Brian
    Life's too short to be in a hurry... Ride a T-Dub Hidden Content
    2013 TW200
    2004 VTX 1300
    Hidden Content The Spirit of the Lizrd Rolls Forever.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,036
    The sprocket has to go all the way on the shaft. The lock ring must push on far enough so the tabs on it reach the grove where it will turn and lock the sprocket in place. When the sprocket is fully seated and the lock ring tabs are in the grove you can only get the screws lined up if the ring locks the sprocket in the correct position. I have no idea how you ever got the screws lined up in the sprocket holes without the lock ring being in the grove but it sure does look like that is what happened.
    1987 Yamaha BW350 Big Wheel
    May 2014
    Twin cities
    182
    Quote Originally Posted by Dubzha View Post
    Spring Lake Park
    May 2014
    Twin cities
    182
    About to take the chain off now.
    6,975
    It looks like the sprocket wasn't on far enough when you installed the keeper plate. The keeper plate goes in a small groove then you twist it to align the bolt holes. I bet the sprocket wandered outward and rubbed up against the seal and the keeper that holds the seal in place. For sure you need two new bolts to hold the keeper to the sprocket, and a new outer seal, and probably a new keeper plate that holds the outer seal in place.
    Post a picture of the inside of the left side cover -- the part where the output shaft goes into the left side cover. I bet it is chewed up.
    May 2014
    Twin cities
    182
    6,975
    Quote Originally Posted by 1RobAusdemore View Post
    You didn't have the sprocket on all the way.
  1. Front sprocket
    Last Post: 08-27-2013, 03:24 AM
  2. New rear sprocket install?
    By GaryL in forum Technical Help
    Last Post: 07-26-2013, 08:14 AM
  3. Front Sprocket
    Last Post: 09-30-2012, 07:46 PM
  4. Problem after JT47 sprocket install?
    By triple3jrb in forum Technical Help
    Last Post: 02-07-2012, 07:49 AM
  5. JT 47 tooth sprocket install questions
    Last Post: 12-19-2011, 02:07 PM
neutral safety switch
