Where does this wire go?
Results 1 to 4 of 4
    Member tok-tokkie's Avatar
    Cape Town, South Africa
    88
    I have had my engine overhauled. I am now re-fitting the engine & I have this wire which I don't remember where it went.
    Can anyone tell me where it goes. I suspect it may be the neutral indicator but I don't want to take the cover off unless I am sure. It looks like the round push in connector fits into the collection with the alternator wires at the battery.
    Second question. There is a two part rubber tube on the carb. 1 part goes down & is the overflow. Does the other part just goe up under the tank threaded next to the wire loom as a breather? That is what I remember but it was quite a while ago when I removed the engine & the TW workshop manual has very poor photos but says nothing about these tubes. There is a separate larger rubber tube that starts between the carb & cylinder head leading up the same way ending in a metal tube thing.
    Devon, England.
    614
    Looks like your neutral light switch wire. It goes just by the gear shifter (forked end) and plugs in the other end by the battery there are a few wires in a rubber sheath.
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    Quote Originally Posted by uktw125 View Post
    Hello,
    Exactly...
    88
    Quote Originally Posted by christddel View Post
    Hello,
    Exactly...
    Many thanks. I thought so but did not want to take the cover off without being certain.
  1. Cdi yellow wire
    By GrantM in forum Technical Help
    Last Post: 04-29-2013, 10:11 AM
  2. Burnt red wire
    By snakefoot in forum Technical Help
    Last Post: 07-15-2012, 08:15 AM
  3. How to change the spark plug wire?
    By Sverige21 in forum Technical Help
    Last Post: 05-27-2011, 08:37 PM
  4. Spark plug wire change
    Last Post: 04-20-2011, 08:30 PM
  5. Wiring Question - Where does this wire go???.
    By Grant in forum Technical Help
    Last Post: 12-25-2010, 12:31 PM
