Sta-Bil or Sea Foam?
Results 1 to 7 of 7
Like Tree4Likes
  • 2 Post By Bruce's
  • 2 Post By Adam-n-nevada
Thread: Sta-Bil or Sea Foam?
    Senior Member Dave-o's Avatar
    Jul 2014
    Tulsa, OK and Table Rock Lake, MO
    123
    I have a boat, lawnmower, string trimmer, chain saw, leaf blower, and now my beloved TW200.
    I've always added Sta-Bil fuel stabilizer to my gasoline because I don't know how long it will be until it is used. I've never had a problem with my fuel, even after being stored long-term.
    I've seen hundreds of opinions stating a preference for one or the other, but nothing to sway me to change... so far.
    What say you?
    Senior Member Bruce's's Avatar
    May 2014
    258
    Sea foam is a better product ,it will clean out your carb and other things while you use it .I have too many bikes (29 at last count ) ,sometimes it's a few years between riding them depending on where they are parked in the garage ,I run sea foam and have no problems even if I leave the bike for 3 or 4 years .If your having a fuel issue ,often running a bit of sea foam will clear up the problem without doing anything else .
    Adam-n-nevada and B-dub like this.
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    I also like the Seaform - for it's multipurpose attributes as Bruce has mentioned. I figure, why just use a fuel preservative, when you can have a fuel preservative, stabilizer, carb cleaner and upper cylinder cleaner too.
    Fred and B-dub like this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    SEAFOAM was developed for the harsh Marine environment! That ought to tell you all you need to know. I too have had good results with marine Stabil and Lucas products but a few years back I switched to SeaFoam and will never go back. If you can get Non Ethanol gas in your area I would highly recommend using it exclusively in your TW and all your small engines and so too would Yamaha and all the other manufacturers.
    1987 Yamaha BW350 Big Wheel
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    734
    I have used both. Another guy told me about sea foam for his small engines that didn't get run a lot. My tractor starts right off with it in the gas, I leave it in over the winter. Added some to fresh gas in the tdub and that sat all winter and it didn't even think about not starting.
    2005 Tdub
    Senior Member JS5owner's Avatar
    Palm Springs / Desert Hot Springs
    308
    +1 on Seafoam! It has resurrected several "gummy" carbs for me without having to open them up.
    2007 TW "Muley": Cyclerack rear, 55 tooth rear sprocket, Duro Power Grip & Shinko SR241, Clarke tank, Ricochet bash plate, Mule hitch pin quick seat removal, Trail Tech Vapor w/ Dashboard, hardwired Garmin 60csx & 205w, 12vdc adaptor, independent high beam off/on and signal beeper, modified seat.
    2000 Yamaha V-star 650 Custom - [sold]
    2009 Yamaha WR250R - "Willie Boy" the slimmer faster brother of my Muley.
    2009 Hidden Content . Wow, what fun on the highway!
    Jul 2014
    123
    Thanks guys! I appreciate the responses!
  1. Foam
    By frog13 in forum Performance and Customization
    Last Post: 04-26-2014, 04:36 PM
  2. sea foam motor treatment
    By gussy78 in forum Technical Help
    Last Post: 05-15-2013, 03:57 PM
  3. "Uni"versal air filter foam
    By PalmStateCrawler in forum Performance and Customization
    Last Post: 03-09-2013, 10:57 AM
  4. OEM seat cover and foam
    By WhereTheHellIsJames in forum TW200 Classifieds
    Last Post: 11-02-2012, 01:14 AM
  5. Marvel Mystery Oil vs Sea Foam
    By thumper in forum Technical Help
    Last Post: 02-07-2011, 06:08 PM
