Valve clearance
Results 1 to 10 of 15
Like Tree16Likes
Thread: Valve clearance
    Senior Member fielding's Avatar
    Jul 2014
    Southern Utah
    197
    Valve clearance
    The service manual I received with my TW200V does not give the valve adjustment clearances. There is a note saying this has to be done by the dealer. I have always done my own adjusting in the past. Is there something special about the TW that prevents me from doing the valve adjustment?
    What is the spacing supposed to be? .001 In.?
    Also what is the significance of the V part of the model TW200?
    Any help much appreciated. This is my first experience with Yamaha.
    18,714
    All your questions are well answered by "Similar Threads" links on bottom of this web page.
    Whether or not you re-use o-ring seals on valve cover gaskets be careful to not over tighten covers. New o-rings and very, very little torque prevent leaks or damaged retaining bolts.
    fishguy, fielding, SanDue and 1 others like this.
    Spokane, Washington
    17,286
    Intake .05-.09mm or .002-.004in
    Exhaust .11-.15mm or .004-.006in
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member Indiana's Avatar
    Oct 2013
    Indiana, 40 miles south of Indy
    470
    Fielding, here is a link to a page here where you can download the service manual and the service manual supplement fore 2001 and newer models. I don't remember what year you ride, but I recall the valve clearances being different for the old and new models.
    https://tw200forum.com/forum/technica...r-manuals.html
    To find TDC it is easiest to take off the timing chain cover on the left side, top of the engine and align the mark on the cam sprocket to the "bump" cast into the head. The "bump" is roughly at the 12 o'clock position.
    Fred and fielding like this.
    Jul 2014
    Southern Utah
    197
    Thanks. I did find the online service manual. It's more complete than the one I have. I am going to adjust the valves sometime this week, I can hear them clicking a little. Maybe I will do the cam chain at the same time.
    Jul 2014
    Southern Utah
    197
    Quote Originally Posted by Indiana View Post
    Good advice. I'll see what I can do with it. Thanks.
    Ron
    Ron is offline
    Member Ron's Avatar
    Dec 2014
    37
    That repair manual download link leads me to here https://www.mediafire.com/?34muedntyxz Which refuses to download anything. Am I doing something wrong?
    Thanks
    Ron
    grewen likes this.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,388
    that's where it takes me also.......... I gave up
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Oct 2013
    470
    Looks like it was taken down.
    __________________________________________________ _____________________________
    Frosty Hollow
    13,049
    I'm not sure this will work, but I downloaded the manual's. If you pm me your email address, I can try to email you a copy. Not sure this will work due to file size, but maybe I can figure out the whole zip file thing. If someone know's a good way to email large files, let me know as I know different carriers have different email file size limitations.
    I have the main, supplemental, and owners manual.
    littletommy likes this.
  1. Valve clearance spec
    By yz250f4ever in forum Technical Help
    Last Post: 12-17-2012, 08:16 PM
  2. Valve clearance
    Last Post: 07-23-2012, 12:17 PM
  3. Check Valve Clearance
    By ericj in forum Technical Help
    Last Post: 04-04-2011, 02:31 AM
  4. Adjusting the Valve Clearance
    By vuldub in forum Technical Help
    Last Post: 09-01-2010, 07:45 AM
  5. Valve clearance
    By shady145 in forum Technical Help
    Last Post: 08-26-2010, 12:29 PM
2014 tw valve clearance
2014 tw200 valve clearance
2015 yamaha tw200 valve clearance
valve check
