Thank You Admiral
Results 1 to 5 of 5
Like Tree7Likes
  • 2 Post By Fred
  • 3 Post By admiral
  • 1 Post By Bucknutz
  • 1 Post By GaryL
Thread: Thank You Admiral
    18,727
    Thank You Admiral
    In another example of one member helping another and thus making the world a better place I present the following useful tip courtesy of Admiral: After last Rubicon Ride my left foot peg was bent back 45 degrees. Heat, hammering, disassembly, cussing all were ineffective. Posting my predicament Admiral suggested the pry-back method which worked very well. I put 5 ft Johnson bar between footpeg bracket and bottom of frame tubes and levered peg back into shape. Of course I re-damaged it late last night on moonlight trail ride with another rock encounter, but just finished re-bending bracket again.
    Thanks Admiral!
    Sorry for upside down pics, can't figure out why.
    admiral and r80rt like this.
    Senior Member Bucknutz's Avatar
    Apr 2012
    Lower Hudson River Valley of The Communist State of N.Y.
    487
    Thank you Admiral, and Fred. I have the same issue with one of my pegs after I whacked a boulder on the Russ Rally NE ride. I'll try this method. Thanks, Dave
    Frosty Hollow
    13,059
    Guess we'll have a few more people "heading to the bar", so to speak!
    Mel, Fred and rurlndum like this.
    Apr 2012
    487
    Done, Gary L did it for me. Thanks for the Idea. Rubber side down, Dave
    admiral likes this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,048
    I will second that emotion and give Admiral credit for inventing Leverage!
    Keep in mind these techniques either work or they don't. Sometimes I end up with mostly straight and sometimes I end up with two pieces that are completely useless. Can't blame a guy for trying and what I said to Bucknutz before I put my big bar on it, if it brakes don't look at me!
    A good trick member Gregor just taught me about aluminum levers that get bent. Heat aluminum to the point where a piece of wood will leave a charcoal line on it when dragged over it. Aluminum does not like to bend unless it has been annealed! Heat it, quench it quick and bend it. Heat it again after bending and allow it to cool slow. Gregor is our resident metallurgist, blacksmith and machinist. I can usually fix stuff so it works but Greg is the one I call on when I need it done right.
    Fred likes this.
    1987 Yamaha BW350 Big Wheel
  1. Not TW but Asian admiral
    By arrowsmith in forum General Discussion
    Last Post: 05-01-2014, 10:53 AM
  2. Desert Ride with Admiral & Son
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 02-20-2013, 08:32 PM
  3. Happy Birthday- ADMIRAL
    By goldenhtr in forum General Discussion
    Last Post: 12-08-2012, 05:10 PM
  4. A salute for the Admiral
    By Rohnsman in forum General Discussion
    Last Post: 02-28-2012, 07:50 PM
  5. The Admiral made me do it.....
    By Gerry in forum Trails, Off-road, and Adventure Riding
    Last Post: 01-11-2012, 09:30 PM
