Kickstart only
Results 1 to 6 of 6
Thread: Kickstart only
    Member r_marsh's Avatar
    Aug 2013
    Fort Worth
    45
    Kickstart only
    Ive got no problem kickstarting my 1990 so what would i have to do to remove the battery and just run only on the coil?
    Member manotickmike's Avatar
    Apr 2013
    Ontario, Canada
    93
    Jeeze, why?
    I never use the button to start Diane's bike, but I dunno why anyone would want to remove the battery, and change the wiring around.
    Senior Member fielding's Avatar
    Jul 2014
    Southern Utah
    197
    I don't know about the TW, but on a Honda Trail 110 if you remove the battery the generator voltage goes too high and burns out all the lamps. It's the battery that holds the voltage down, even if it's an old battery that won't hold a charge well, it will still hold the voltage of the generator down to where it belongs. Like I say, I don't know if this is true for the TW. It might be different.
    Aug 2013
    Fort Worth
    45
    Just wanting to clean up the look of it
    Senior Member Mr.Paynter's Avatar
    May 2011
    Durban, South Africa
    330
    You need to order a capacitor, which "replaces" the battery, connects to the wiring loom at about 1 20th the size and weight, and is easily tucked away in a tray under the seat (if you're hollow-modding.).
    I've ridden a friends' dub with this idea in use and it was fine.
    Here's a link to a capacitor, not sure if it is the same one he installed:
    POSH : Battery-Less Kit [010068]
    Finally picked up a Tdub...
    Apr 2013
    385
    same as Mr Paynter said
  1. Cannibalising a Tdub for a kickstart...
    By Mr.Paynter in forum Technical Help
    Last Post: 08-01-2014, 07:59 PM
  2. Kickstart Install: What did I do wrong?
    By Tyler in forum Technical Help
    Last Post: 06-05-2014, 10:55 AM
  3. Bending an aluminum kickstart... ?????
    By zardoz in forum Performance and Customization
    Last Post: 10-04-2012, 09:10 AM
  4. Clutch fixed, now Kickstart problems!
    By SCARE! in forum Technical Help
    Last Post: 08-30-2012, 04:23 PM
  5. kickstart and oil cooler installed
    By 6Z37RLC in forum Performance and Customization
    Last Post: 08-18-2012, 01:31 PM
