first valve adjustment scares.
Results 1 to 10 of 18
Like Tree2Likes
Thread: first valve adjustment scares.
    Junior Member the weiand one's Avatar
    Jun 2014
    georgia
    28
    Finally finished everything. Started it up. Actually started up real strong. But idles at a noticeably higher idle than normal. Could just adjusting the valves increase idle rpm. ?
    Germany, Werdau
    1,014
    Short reply: No
    Adjust the idle rpm, when the engine is warm.
    fishguy likes this.
    Hailey, ID
    3,376
    Quote Originally Posted by the weiand one View Post
    TW's idle seems to move around a bit on a random basis, at least mine does....I just adjust it whenever it needs it.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Junior Member bigbear's Avatar
    May 2014
    Big Bear Lake, CA
    Is this problem valve adjustment related?
    Input appreciated: Have 5 riders in a Big Bear Lake TW200 riding club. All the bikes run fine except my 2012..
    Situation: When coming down any reasonably steep off road hill in neutral at slow speeds (2-7) mph.
    Symptom: Sometimes in Neutral she dies, and most times in Neutral the idle speed goes much much higher than regular idle speed.
    As soon as I start approaching level ground the idle returns to normal?
    This happens about 90% of my down hill riding time.
    Bike has 639 original miles, use 87 Octane with Stabil, riding at 8000 feet of altitude, stock carb, stock exhaust, clean new plug ( did before new plug) clean oil, properly chain tension
    Was told that they run lean anyway so no carb adjusting done.
    Valve Adjustment, Carb Float, suggestions really appreciated
    Senior Member dabsdog's Avatar
    Jun 2014
    Painted Post ny
    129
    8000 ft might have something to do with it. Why do you run in neutral going down hill? (I might learn something)
    Jun 2014
    Painted Post ny
    129
    Another thing. Going down a steep hill might shut off the float valve due to the angle. Make sure the carb vent is OK.
    Feb 2013
    Missoula, MT
    908
    Original post: No, valve adjustment alone shouldn't change the idle. Warm up the TW. Adjust idle. Think about adjusting pilot screw to leaner.
    2nd post: Downhill in neutral? Not me. I select a lower gear as required and use engine compression along with brakes as needed.
    I think your carb float is sticking. Try Lucas Fuel System Cleaner or SeaFoam. Stabil isn't keeping up with all the crap they are putting in gas these days. Startron claims to "eliminate" and "neutralize" with "enzymes" the effects of ethanol. Lots of snake-oil but it does work. VERY expensive, tho.
    Hailey, ID
    3,376
    Quote Originally Posted by fishguy View Post
    ...... Startron claims to "eliminate" and "neutralize" with "enzymes" the effects of ethanol. Lots of snake-oil but it does work. VERY expensive, tho.
    It isn't "VERY expensive" if you buy the right bottle. One bottle treats 28 gallons and the same size bottle with a more concentrated mixture treats 128 gallons, but is only slightly more.
    Deceptive marketing, sure, but one 8 oz. bottle of that 128 gallon StarBrite will last me three years or more: STAR BRITE 93008 STAR TRON GAS ADDITIVE 8 OZ#
    Also at Walmart. You have to look carefully at the label, because otherwise the bottles look identical.
    I use it EVERY time I have to use Ethanol gas, and over the winter even with Non Ethanol gas. I run a couple ounces of Seafoam in about every fourth tank. Carb continues to operate perfectly at 10,000 miles.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Padilen's Avatar
    May 2014
    Cadillac Michigan area
    1,598
    I'm doing it wrong ! I'm on my 3rd bottle of Star Brite in a year!
    May 2014
    1,598
    So while I was out in my pole barn I checked my bottle- 48 gallons. I like their math 1oz to 3 gallons of gas. So 3x8 is 24 how do they get 48? They retreat 6 old gallons of gas with 1 ounce. So 6x8 is the 48.
  1. Valve Adjustment Question
    By JRD in forum Technical Help
    Last Post: 11-29-2013, 09:06 AM
  2. Valve adjustment(s)
    Last Post: 06-26-2013, 02:50 PM
  3. Valve adjustment
    By Scotto560 in forum Technical Help
    Last Post: 03-13-2012, 12:07 PM
  4. Valve adjustment?
    By Matthew Rowland in forum General Discussion
    Last Post: 02-07-2012, 11:15 AM
  5. Valve adjustment success
    By bigdreama in forum Technical Help
    Last Post: 10-08-2010, 03:41 PM
