Hard Starting Trick
Results 1 to 8 of 8
    Senior Member thumper's Avatar
    Oct 2010
    232
    How many of you folks have left your TW's sit for a week or more only to have them very difficult to start again?
    Even on battery tenders, if you leave 'em sit for a while it can take several kicks, or cranks on the electric starter.
    Well here's another little trick that I've been doing that has been working very well for me.
    when you park your bike, before you stop the engine, turn off the fuel petcock and let it run out of gas.
    Simple huh?
    I've done this since new on my 08's, and everytime I go to start 'em, no matter how long they've been sitting, they
    usually start the first or second kick! Or within a crank or two when I use the starter button.
    Just thought I'd share.
    Ride safe out there.
    Igofar
    Senior Member trailboss's Avatar
    Sep 2010
    Alexandria VA.
    140
    If mine is hard to start I take out the choke lever and spray starting fliud in it put it back on and vrooom fires right up.
    Junior Member Lewis54's Avatar
    Sep 2010
    Western NY
    20
    I did this for years with my vintage BMWs, and now do it every time on my TW200. Another benefit is that if the bike sits a long time between starts, having a dry carb prevents varnish from building up in the carb and you needing to do a thorough cleaning or rebuild.
    Senior Member Kev250R's Avatar
    Orange, So.Cal.
    284
    A good idea if your TW is going to be sitting for a while. You can also turn the petcock off then drain the carb's bowel using the small screw located at the bottom of the carb (bowel) which has a rubber tube adjacent to it (it will drain onto the ground or an approved container). I drain the carbs on my ATV's using that method and it works pretty well. Oddly enough I personally never drain the carb on my TW as I generally try to ride it every couple of weeks, however Sunday I realized that I hadn't started or ridden my TW in six weeks so I fired it up and went for a quick ride around the block. Some bikes seem more prone to having the carbs gum-up on them then others, luckily the TW seems to be one which seems to be resistant to carb gumming (thankfully).
    Kevin
    '04 TW - Ricochet skid plate, IMS pegs, Odyssey battery, Seat Concepts seat, wide front tire. Geared low N' Slow Hidden Content
    Honda Grom
    KTM 990 Adventure
    Always turn off the gas and run the carb dry before transporting any motorcycle with a carb. Bouncing around on a trailer or in a vehicle will jiggle the float, allowing the bowl to over-fill with gasoline, potentially causing engine flooding and oil in the combustion chamber, with all that scenario's evil consequences. The same effect can be had merely pushing a bike around a garage or rolling it onto a motorcycle lift.
    Senior Member tripleted's Avatar
    B.C.
    136
    Run Seafoam through it on your last tank of gas before you run it out of gas.
    866
    Ride the bike so often that it always has fresh gas in it.
    Senior Member Two Shoes's Avatar
    High Desert, California
    110
    Quote Originally Posted by Rodney View Post
    That's what I do. It works great!
  1. 130 main, shimmed needle, now hard starting
    By Loppy in forum Technical Help
    Last Post: 09-14-2012, 08:35 AM
  2. Hard starting
    By cjnett1 in forum Technical Help
    Last Post: 09-07-2012, 06:51 PM
  3. Hard starting bike
    By Vlakslee in forum Technical Help
    Last Post: 01-02-2012, 07:24 AM
  4. Hard starting? 2 tips for TW noobs
    By Rezolution in forum Technical Help
    Last Post: 09-06-2011, 07:11 PM
  5. Hard Starting
    By thal13 in forum Technical Help
    Last Post: 05-20-2011, 08:11 PM
honda tw200 hard to start
