What quality of bearings
Results 1 to 10 of 10
    Senior Member christddel's Avatar
    Oct 2010
    Belgium
    376
    The quality of bearings...
    On the crankshaft is the C3
    But my question ?
    for the gearbox C2, C3, C4 ?
    After disassembly, I have only these references...
    xx-xx-xx The measurements are in millimeters
    Take the bearings to a bearing supply house to match up, but do not be surprised if they are proprietary sizes and only available from Yamaha.
    Oct 2010
    Belgium
    376
    Thank you for your reply.
    I have found a supplier for these bearings.
    But, I was offered the same bearing in different quality finish. C2, C3, C4...
    What is the best for (axis) gearbox ?
    Devon, England.
    614
    The codes c2,c3,c4 are different internal clearance specs. to allow for different rates of expansion of the inner and outer race.
    If there is no c# number then they are standard clearance.
    A bearing with more clearance than standard is safer to use if you do not know which is correct, so I would use c3 (more than standard clearance than standard) if I could not find out the full and exact spec.
    Oct 2010
    Belgium
    376
    Quote Originally Posted by uktw125 View Post
    Thank you for the information technology.
    I'm reassured ...
    My bearings are ordered.
    Oct 2010
    Belgium
    376
    I received the bearing...
    Now the reassembly of the engine...
    Changing the crankshaft Modified stroke 48.8 mm ---> 62 mm. (Work TW-parts)
    Changing the piston 57 ---> 73mm.
    Cylinder/Sleeve 225.
    Calculate this is ...259cc only...
    Changing gearbox TW125 5 speed for TTR 225 6 speed.
    259,598428571428571428571..., actually. You are building a TW260. Try to keep it down to 160kph.
    Devon, England.
    614
    Great build, please keep us up to date as you progress.
    Oct 2010
    Belgium
    376
    Following the mounting of the cylinder 73mm.
    I must know the volume of the combustion chamber
    With 30 cc combustion chamber volume, I put a head gasket + fin ...
    Junior Member RobRz's Avatar
    Jun 2012
    Sydney, Australia
    16
    Hi christddel, did you replace the left side crank bearing? if so how did you get the cam chain sprocket and old bearing off?
    cheers
    Rob
  1. Where to buy quality O-Ring Chain?
    By Matt in forum Performance and Customization
    Last Post: 11-20-2012, 06:57 PM
  2. How to remove front bearings?
    By Guit4eva in forum Technical Help
    Last Post: 09-08-2012, 07:26 AM
  3. Steering Head Bearings
    By Rainman in forum Technical Write-Ups
    Last Post: 04-28-2012, 07:54 PM
  4. greasing the steering bearings
    By cdsdave in forum Technical Help
    Last Post: 04-07-2012, 01:37 PM
  5. Fork Bearings?
    By retro in forum Technical Help
    Last Post: 10-10-2010, 02:48 AM
left crank bearing c2 c3
