Large mileage - what bits will need changing.
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
    Member UKJ's Avatar
    72
    Hi all, need a bit of advice. Almost finished prepping the tw225 for a bit of a trip, now in the process of ordering some consumables.
    First leg of the trip I expect will be around 24,000 miles. Ignoring a possible need for major repair parts, am I going to be OK working on the following mileage intervals?
    Bike is having a full service before I set off, all the below will be brand new at the start of the trip, I'm running stock bridgestone rear knobblies and Pirelli Mt21 or Bridgestone tw302 fronts.
    Tyres every 8000 miles
    Tubes as and when needed
    WheelBearings every 8000 miles
    Pads every 8000 miles
    Oil every 1000 miles
    Oil Filters every 2000 miles (cleaned at every 1000)
    Air filter regularly cleaned (and replaced every 8000 miles)
    Sprockets/Chain every 8000 miles (will be running X-ring/O-ring chain).
    Cables/Headstock bearings/swingarm bearings - Halfway point
    Of course general maintenance will be kept up, valves/clearances - grease etc
    Do those seem OK? My Big problem is most of the parts won't be possible to buy on route so they will be posted to friends in countries at around the 8000 mile marks. I can carry some basics with me but not alot.
    Riding will be 50/50 on and off road I'd hope. I know alot of this depends on riding style/terrain but I'm just trying to get an idea.
    Any thoughts/advice?
    Not too worried about bearings/pads etc as I can carry some spares - mainly the chain/tyres that are going to be difficult/expensive to get hold of.
    Senior Member Hobopoet's Avatar
    Sep 2010
    240
    I must have missed something. Where, exactly, are you headed?
    Member jonah's Avatar
    51
    Wow that sounds like quiete the endevor. What is this trip you're taking? Sounds like those long way round/down trips those guys Ewan and charley took.
    2005 TW200
    T-dub+rifle+predator calls=FUN!
    Member UKJ's Avatar
    72
    It's a bit of a "make it up as we go along" trip, but certainly from the UK down to Portugal, Morocco, Africa, Italy, Alps, Balkans, Eastern Europe - Then stop for the winter, see how money/bike etc are and then eastwards/upwards hopefully.
    I leave in April, and meet up with some others at various points but itll be largely solo.
    I don't quite have the budget for a Ewen/Charlie support team/4x4s - , just a hammock and everything thatll fit on the back of the TW.
    Senior Member BBMS's Avatar
    Nov 2010
    Pensacola, FL
    103
    Pack something with which you can maintain a blog, so we all can read about your adventure. Pics are a must.
    Senior Member jonjon122's Avatar
    Jan 2011
    Tombstone Arizona
    102
    that is quite a trip =)
    -Respect the person who has seen the dark side of motorcycling and lived.
    -Winter is Nature's way of telling you to polish.
    -A good rider has balance, judgment, and good timing. So does a good lover.
    -Everyone crashes. Some get back on. Some don't. Some can't.
    -Only a Biker knows why a dog sticks his head out of a car window.
    -'Oh S$$t!' is usually the moment when your plan parts ways with reality
    -Well-trained reflexes are quicker than luck.
    -Don't lead the pack if you don't know where you're going.
    -What do you call a cyclist who doesn't wear a helmet? An organ donor
    I don't think you will get 8000 miles out of a knobby front tire.
    Senior Member Boret's Avatar
    Aug 2010
    Northern VA
    404
    It seems a bit too much to change the oil every 1000 miles. I am sure you can get 2000 even 3000 out of good quality oil.
    Senior Member darnold87's Avatar
    Salem, OR
    908
    Holy cow that's a huge trip - exciting to hear you're taking a T-dub and not a GS or something! Good luck and keep us updated on this...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Member UKJ's Avatar
    72
    - I was hoping the tw302 would manage that sort of mileage - it's a fairly large/heavy tread - not as knobbly as the mt21s etc. The front is not such an issue as the size is a bit more common and I should be able to pick one up in most of Europe - the rears are difficult to find in knobbly tread over here, even worse in North Africa/Eastern europe.
    On that note - what's a sensible psi to be running in the stock rear/tw302 front with getting lots of miles out of them as a priority.
    Quote Originally Posted by Boret View Post
    I figure I'm expecting this little bike to do 25,000+ miles through desert/dirt/mountains etc - least I can do is give it a drink every so often. It'll depend where/what oil I can get but at under $10 per litre it's one of the cheaper things to keep on top of.
    I'm in the process of setting up a little blog
  1. Replies: 4
    Last Post: 07-19-2011, 03:41 AM
  2. FS: Nolan N102 silver large
    By neve_r_est in forum TW200 Classifieds
    Last Post: 07-06-2011, 07:13 AM
  3. LARGE storage tubes
    By Ripshod in forum Performance and Customization
    Last Post: 04-27-2011, 12:19 AM
  4. Sputtering on washboard and large bumps
    By Rainman in forum Technical Help
    Last Post: 03-19-2011, 10:39 AM
  5. Can this bike handle a large man?
    By toddler83 in forum General Discussion
    Last Post: 01-10-2011, 12:14 PM
